It is currently Sun May 03, 2026 9:48 pm
 Post subject: v tread heigth
PostPosted: Tue Sep 15, 2009 11:59 pm
how tall does a 31 firestone actually measure mounted as compared to 31 or 33 mounted bogger
 Post subject: Re: v tread heigth
PostPosted: Wed Sep 16, 2009 12:55 am
These were 32" when they were mounted on 10 x 15
Tony
PostPosted: Wed Sep 16, 2009 9:17 am
It will vary depending on rim and tire withe. the closer you are to the recommended rim withe for the tire the closer you will be to the listed tire height. The narrower the rim the taller the tire will be. The wider the rim the shorter the tire will be. I mounted a set of 15 X 15 X 31" "V" threads on a set of 12" wide rims with beadlocks and they were 29" tall. The same rims with 15 X 12.5 X 33" Boggers are 32" tall.
