It is currently Sun May 03, 2026 10:59 pm
 Post subject: Cutting Firestones
PostPosted: Fri Jul 31, 2009 4:59 pm
I've got these uncut 4ply Firestones and I'm wondering how much rubber I can cut before I go to far. Man these pics are small.
 Post subject: Re: Cutting Firestones
PostPosted: Fri Jul 31, 2009 6:01 pm
To the first layers of chords. Cut right to them, until you can see them through the rubber. Try to avoid cutting into the chords, just cut right to them. Be sure to cut plenty off of the ends of the lugs at the center of the tire to allow the tires to flex properly. 8)
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Fri Jul 31, 2009 8:12 pm
I wouldn't be afraid to say that there are some guys out there that will trade you some cut 8 plys for them uncut 4 plys,,,and I must say the 8 plys are very good tires too. That is if you are a little lerious of cutting tires. :wink:
PostPosted: Fri Jul 31, 2009 10:20 pm
Take Coco's advice he's awesome when it comes to tire cutting.
PostPosted: Thu Aug 06, 2009 12:53 pm
Thank ya, Dave! I appreciate it.
Man, when're ya gonna get back to D&K to ride with us again? You were a blast to ride with!
-Dakotah/koko
-Dakotah/koko
PostPosted: Thu Aug 06, 2009 1:30 pm
Yea, I have a set of cut 8 ply "V" threads I will trade ya. They have plenty of meat left on them.
Steve
216-605-0733
PostPosted: Thu Aug 06, 2009 6:04 pm
Rome Ohio is a little bit out of the area, thanks anyways. Thanks KOKO on the depth. I guess I'll take a knife and cut down to find the depth, then set the router and have at it. I'll make a jig platform to set up against the ribs to cut close to them and not go down too far.
PostPosted: Thu Aug 06, 2009 6:14 pm
Be careful doing that with a router. the rubber depth can be very inconsistent, and you'll buzz right thru the cords at a high spot and never know it. It takes a good touch and ear to know when you are hitting cords with a big cutter so you know when to lift a little. You'll never know over the noise of a router, until you feel the air rushing out of the gaping hole. :shock: Thats a sick feeling, let me tell ya.
Guess you could set it pretty shallow and then finish up with a less aggresive technique. :?:
