I recently purchased a vucanizing compound to repair 3 holes sustained in one of my rear tires at Wellsville. This compound is a life saver for off road tires. One of my holes in the side wall was a 1/4" gap by 1" long. After 48 hours of set time I put it on the rim and pressureized it high enough to seat the bead and its held fine. So whats that tell you about the product. The problem with this batch is the Expiration date is 6/09 meaning it needs to be used soon. It worked fine on my tire however by the next time I will need it it will probably be unusable. Well at least I am hoping I dont need it for awhile
. The manufacture is sending me a replacement batch. So if any of you has a tire that you think you can save I am offering the compound free of charge just so it does not go to waste. I have been told you can Increase the shelf life by keeping it refridgerated and thats were its at now. I hid it and my wife has not found it yet so time is running out.
