It is currently Sun May 03, 2026 2:11 pm
 Post subject: back tire
PostPosted: Mon Mar 16, 2009 1:17 am
im running boggers now but they r getting old and i am wondering what u think about buckshots they way cheaper than a bogger r they any good to have
 Post subject: Re: back tire
PostPosted: Mon Mar 16, 2009 6:28 am
I like a cut buckshot...cheaper and lighter than bogger. don't go to tall.
PostPosted: Tue Mar 17, 2009 1:59 am
i was thinking a 36 inch that good
PostPosted: Tue Mar 17, 2009 9:44 am
36 inch with 3 rib is good if you dont have too much power,,, its always something :?
PostPosted: Tue Mar 17, 2009 1:11 pm
I thought they stoped making Buckshots ? We ran p then Q then R and R are called 36in but they are only like 33 in tall
PostPosted: Sat Mar 21, 2009 9:11 pm
They quit making the R (36 inch). Keith mitchell still has some in Alabama. 205-752-0962
PostPosted: Mon Mar 23, 2009 4:49 pm
i am going to put a 5 rib in it soon and i have a 2110 what dose he charge for them if anyone knows
PostPosted: Mon Mar 23, 2009 11:19 pm
Jesse, I have got a set of cut Q buckshot tires on 4 lug rims. When you put the 5 rib (4.86) trans you are welcome to try my Q's. I think the R's are too big for a 4.86 and a 2110 cc motor. This way you could figure it out before you buy tires.
PostPosted: Tue Mar 24, 2009 1:06 am
how big r the Q's
PostPosted: Tue Mar 24, 2009 10:30 pm
36/12.50 swamper they have taller lugs and they run down the side of the tire and run them on 7" wheels. They hooked great in fultondale.
PostPosted: Thu Mar 26, 2009 12:42 am
thanks for the help i will take u up on that its going to be the weekend after the hillclimb here when i go get the trans
PostPosted: Wed Jun 24, 2009 3:43 pm
what size would be good with 3 rib witha 1835
PostPosted: Thu Jun 25, 2009 1:24 am
31s or even 33s should be fine if its a decent built 1835 just be good with the clutch if it jumps off the ground.
a stock tranny cant handle much of that especially if you cut the tires
PostPosted: Sat Aug 15, 2009 10:31 pm
im running an old set of goodyear terra's right now... (with only about maybe 50% of tread)they do ok as long as the ground is dry.. lol.. but just bought a set that is like new.... very cheap.... i haven't mounted them yet thought... how good are the compared to boggers or buckshot....???? there 31 15 50's and they will be on a 10inch rims...
PostPosted: Sat Aug 15, 2009 11:55 pm
well if u put the terra tires on your tranny will last alot longer than if u had bogger,boggers that are cut right are hard on trannys,stay with the terras
