| Tire cutting redneck style! http://woodsbuggy.com/phpBB3/viewtopic.php?f=29&t=5602 |
| Author: | ImmortalSoul219 [ Sat Jan 17, 2009 11:21 am ] |
| Post subject: | Tire cutting redneck style! |
Ever wonder how to to get more life out of those worn out tires? Do you have a chainsaw? HAHA http://www.youtube.com/watch?v=7FSkFZcTWXI |
| Author: | Odyknuck [ Sat Jan 17, 2009 2:49 pm ] |
| Post subject: | Re: Tire cutting redneck style! |
Thats different. I would thik you would want to have someone hold the tire when your doing it. Would not take much for the saw to grab the tire and go all the way thru. |
| Author: | hillaholic [ Sat Jan 17, 2009 5:11 pm ] |
Odyknuck wrote: Thats different. I would thik you would want to have someone hold the tire when your doing it. Would not take much for the saw to grab the tire and go all the way thru. I wouldn’t trust the best lumberjack if I was holding that tire. |
| Author: | kendel [ Sat Jan 17, 2009 5:46 pm ] |
A true red neck would have left the tire on the truck! |
| Author: | nickschlemer [ Sat Jan 17, 2009 6:09 pm ] |
kendel wrote: A true red neck would have left the tire on the truck! Great point.! |
| Author: | Firebug [ Sat Jan 17, 2009 6:36 pm ] |
Actually ,,our good buddy Tanner has done this ,,,,,and had me thinking about doing it myself |
| Author: | harleyhunter05 [ Sat Jan 17, 2009 6:46 pm ] |
alot of the guys i used to ride with always used a chainsaw -- they still do, even to sharpen lugs |
| Author: | jesse [ Sat Jan 17, 2009 8:18 pm ] |
i did this a few years back and worked good faster to |
| Author: | Baddvw [ Sat Jan 17, 2009 9:19 pm ] |
Looks pretty slick, but will it build up a lot of burnt, melted rubber material up into the chainsaw? If it does, looks like that they will have to clean it up more often to prevent further damage if it would. I may try it on my new tires |
| Author: | ImmortalSoul219 [ Sun Jan 18, 2009 4:33 pm ] |
kendel wrote: A true red neck would have left the tire on the truck! HAHAHAHA LMAO I was looking for the nady or PBR sitting around in the vid lol. I guess use what ever gets the job done! |
| Author: | plumberbill [ Tue Jan 20, 2009 11:43 pm ] |
just for shits and grins i had to try this while cutting my boggers. it worked good for cutting grooves but when it came time to remove the small lugs my tire groover worked alot better. |
| Author: | Kyle [ Wed Jan 21, 2009 11:21 am ] |
small lugs just take a 1.5 inch wood chisel and heat it with a torch (doesn't take much), then push it right threw those little lugs like butter. you can shave a 35 bogger in under 20 min. |
| Author: | plumberbill [ Sat Jan 24, 2009 10:05 am ] |
Kyle wrote: small lugs just take a 1.5 inch wood chisel and heat it with a torch (doesn't take much), then push it right threw those little lugs like butter. you can shave a 35 bogger in under 20 min. i wish it went that fast |
| Author: | Kyle [ Mon Jan 26, 2009 2:57 pm ] |
heh it does plumber only take about 20 min a tire, well taking the little lugs out is really what i was talking, now shaving the rest down? talk 6-12 hours lol. |
