 Post subject: Bogger cutting
PostPosted: Mon Dec 29, 2008 1:31 am
I’m just about done with cutting my boggers to the cords. The 35x14.5x15 boggers feel lighter then my 31" firestones after cutting and grinding the side walls. Just wondering if anyone ever cut every third medium lug out on boggers? Just trying to get the best action out of them I can also I need to return plumber bills cutter soon.
I should be done tomorrow and will post pictures of them when done.
Brad
 Post subject: Re: Bogger cutting
PostPosted: Tue Dec 30, 2008 4:17 am
I finally got them done. The original weight of the 35x14.5x15 boggers new was 74lbs. After cutting and grinding I got them down to 49lbs.
This was not an easy job. I started cutting between the lugs with the cheap groover. It was taking to much time so I borrowed Plumberbills professional groover, but the head was to large to fit between the lugs. I was going to quit but then Paul and I did some trading and he finished cutting between the lugs with the cheap groover. After Paul was done I borrowed Plumberbills good groover again to cut the side walls and Deans grinder to finish off the side walls. It’s not easy knowing when you hit the belts with the grinder but I hope they will hold up.
I am going to run them a few times and see how they do before I make my decision on cutting every 3rd medium lug out.
I wanted to thank Paul for doing most of the work, Plumberbill and Trent for the use of their groovers, and Dean for the use of his grinder. I ended up buying my own grinder to finish the job.
This is just the rubber from the side walls of 2 tires
I hope the side walls will hold up. I cut and ground a little to much on this side
No thread inserts on duralights. Not sure if thats a good thing or bad thing
PostPosted: Tue Dec 30, 2008 7:43 am
Oh oh, can I try em?
PostPosted: Tue Dec 30, 2008 7:45 am
looks like you worked your ass off hope they work well for you
PostPosted: Tue Dec 30, 2008 10:35 am
Wow,,,I want a set like that,,,what width beadlock are they mounted on? Another step you could do is sharpening the lugs like the vtread folks do.
PostPosted: Tue Dec 30, 2008 8:11 pm
what did you use?
PostPosted: Wed Dec 31, 2008 1:33 pm
Sure
14" wide. They look wider because I cut so much of the side walls.
nickschlemer wrote:
what did you use?
Van Alstine Tire Groover
Ideal Brand groover with a 1/2" head and blades
4" Tire Grinding Disc
PostPosted: Thu Jan 01, 2009 8:04 pm
Wow! Only one Bud Light for all of that work?
PostPosted: Thu Jan 15, 2009 6:48 pm
they look like they would climb the gates of hell!!
PostPosted: Thu Jan 15, 2009 10:59 pm
lol, I hope they will help me up this hill. I still haven’t made it after 3 tries.
PostPosted: Fri Jan 16, 2009 12:50 pm
damn brad looks badass.. I can't wait for wellsville, you me and kyle(martin) will just go get drunk and stupid, woooooo hooooooooooooo!
PostPosted: Fri Jan 16, 2009 5:53 pm
No Jeffy, we'll be to busy RIDING. You can have fun with all the stupid you want. :P :P
