 Post subject: Inner tubes
PostPosted: Sun Jun 22, 2014 3:14 pm
Easy question for who ever, pretty sure I know the answer but ill ask anyway is there any inner tubes out there that are better or tuffer that others I know a flat is a flat if it got pinched or has a stick poking out of it its still flat I just had a three tube weekend and my tube stash is thin and its time to restock so any help is welcomed
 Post subject: Re: Inner tubes
PostPosted: Sun Jun 22, 2014 3:48 pm
off road center in cleves has some decent ones
PostPosted: Mon Jun 23, 2014 7:47 am
ImageImagei use these tubes they have a screw on valve stem with external threads so they wont move when you air down.
PostPosted: Mon Jun 23, 2014 12:04 pm
@Rick
where do you get those tubes from? Thanks
PostPosted: Mon Jun 23, 2014 12:23 pm
My experience with inner tubes says they suck. The biggest reason they go flat is they get pinched in between the wheel and the tire, with out a tube you wouldn't even know it happened. When you get a flat the tire has to come off the wheel the fix the tube, read pain in the ass. If a tubless tire gets a flat all they need, usually, is a plug or two, the tire doesn't have to come off the wheel. Having said that it is a good idea to have a tube handy in case you get a large cut, something to get you out of the woods with.
PostPosted: Mon Jun 23, 2014 1:05 pm
We ran tubes for years and had flat after flat.took them out and problem went away except for a occasion. It was always a pinch
PostPosted: Mon Jun 23, 2014 1:37 pm
JR1915VW wrote:
@Rick
My local goodyear tire store.. I could not imagine going to the woods without tubes, but then again i wouldn't take the engine out of my wifes car and go to the woods either :twisted:
PostPosted: Mon Jun 23, 2014 2:20 pm
Lol wow wasn't trying to start a air vs water debate just looking for decent tubes I do like this from the Goodyear store though I'll have to look into them thanks rick
PostPosted: Mon Jun 23, 2014 3:36 pm
Its all in good fun.
PostPosted: Mon Jun 23, 2014 4:08 pm
That's a fact, besides your wife wold kick your ass if you took her motor. :P
PostPosted: Mon Jun 23, 2014 4:11 pm
You can get groceries with em pretty fast:lol:
PostPosted: Mon Jun 23, 2014 4:26 pm
Your right both mikes!!! But her car would make a good donor 2013 impala 3.6 all aluminum v6 with 306 hp.
PostPosted: Mon Jun 23, 2014 4:33 pm
You getm real fast with that!!!!!:shock:
PostPosted: Thu Jun 26, 2014 10:20 pm
Back to tubes. What kind of psi you guys run with tubes on a front tire?
PostPosted: Fri Jun 27, 2014 7:47 am
20 psi for me
PostPosted: Fri Jun 27, 2014 8:57 am
My buddy runs about 10lbs and I guess it works for him lol!!!Image
PostPosted: Fri Jun 27, 2014 9:11 am
Lol..... That's the reason I added these to the stock VW rims
PostPosted: Fri Jun 27, 2014 9:21 am
I run these tubes from tractor supply in my 31 15.50 tires and I've never pinched a tube. I think it's because the tube is a little undersized so it doesn't get into all the little crevices to get pinched. And they are only $28.
http://www.tractorsupply.com/en/store/l ... _vc=-10005
The only down side is the valve stem sucks. But with my beadlock wheels and cordless impact gun I can change a tube in 20 minutes
