 Post subject: Wheel adapters
PostPosted: Fri Mar 29, 2013 9:28 am
I need some wheel adapters from 4 lug VW to late model wide 5. I haven't had any luck buying any so I decided that I'd just make my own. The problem I'm having is determining the exact radius of the wide 5 bolt pattern. Does anyone know what it is? I think the pattern is 10.25 but I don't believe that is the diameter.
 Post subject: Re: Wheel adapters
PostPosted: Fri Mar 29, 2013 10:37 am
I have a set here I can measure I didn't get to put them on yet so it'll be convenient let me know what all u want measured and ill post pics of it
PostPosted: Fri Mar 29, 2013 10:46 am
I just need to know what the radius is for the wide 5 bolt pattern. I don't know how you can take a measurement from your adapters.
PostPosted: Fri Mar 29, 2013 11:01 am
I think afterburnt might be able to give you the numbers off center . I know when we made mine at his place he jotted numbers down and handed the paper to me and set here begin ! 8)
PostPosted: Fri Mar 29, 2013 3:37 pm
That would be great if he still has that number!
