It is currently Sun May 03, 2026 5:30 am
 Post subject: spindle rim bearings
PostPosted: Thu Feb 28, 2013 9:24 pm
These are for a link pin front end i was gonna put new bearings in the wheels but i cant seem to find them online anywhere they look like bearings out of the crank or wheels on a bicycle i guess it would be caged ball bearings any of you guys run this kind and if so where do you order or get yours from
 Post subject: Re: spindle rim bearings
PostPosted: Thu Feb 28, 2013 9:32 pm
My stock link pin bearings where caged ball type, the new ones That came with rotors were tapered roller type...... Never mind I just saw the spindle mount part
PostPosted: Thu Feb 28, 2013 9:35 pm
I think this is what you need?
http://www.appletreeauto.com/KING-PING- ... LED-A1019/
PostPosted: Thu Feb 28, 2013 10:25 pm
Mine dont look like that ill pull my rim off tommorow and take a pic of it and try to upload it on here they look identical to crank bearing in a bicycle you could take the tabs on the bearing cage that hold the round ball bearings in and bend them with little effort to pop the bearings out ill see about getting pics up tommorow though thanks again
PostPosted: Fri Mar 01, 2013 1:55 am
Thats what mine was was the ball bearing type but i upgraded to the roller bearing type i think they no longer make the ball bearings
