PostPosted: Sun Sep 02, 2012 12:15 pm
I have a "family friendly" 4 seater buggy that I built. It is basically on a zero budget. The tires I have for it are very mild compared to what a lot of you guys use, but it is all I have. I mostly drive on dirt roads and dry grass because I have 2 very little kids and can't get too wild with them. However, even on dry grass these tires kind of suck. I was thinking about removing some of the lugs on the tires hoping to make them a little more aggressive. I added one picture to show you what I am dealing with 1) What pattern should I chose? I was thinking maybe take out every other rectangular lug. 2) HOW does someone with no money remove lugs? 3) Is this a huge waste of my time?
PostPosted: Sun Sep 02, 2012 5:58 pm
you can buy a cheap groover from day racing for 59 bucks...or you use a propane torch and heat up flat chisel with long handle...not sure how many ply tire you have so might want to go too deep at first....maybe couple practice runs on an old tire...if you get too crazy you can always throw a tube in them
PostPosted: Sun Sep 02, 2012 6:42 pm
This will sound crazy but I have seen it done.. You can use a chain saw to remove lugs.. I would do some diagonal cuts . Tape it off 1st so you can follow a pattern
PostPosted: Sun Sep 02, 2012 8:15 pm
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
PostPosted: Sun Sep 02, 2012 8:41 pm
I have access to a grooving tool. I have also used a sawzall. File a long sawzall blade down to a knife edge. Place it in your sawzall, and cut out whatever tread you want. Just by looking at the tire in your pic, i would cut all the bar tread out and leave the z pattern tread.
PostPosted: Sun Sep 02, 2012 10:38 pm
Is that you MM in this vid? :lol:
I
PostPosted: Sun Sep 02, 2012 11:07 pm
Sorry... I have seen it done but never tried it myself... I would end up cutting the tire in half..
PostPosted: Wed Sep 05, 2012 8:35 am
i have some real cheap v treads on rims if your in ohio
PostPosted: Wed Sep 05, 2012 10:06 am
update your profile, let us know were your from im sure somebody would be close to help you.
PostPosted: Thu Sep 13, 2012 2:56 pm
Hi guys, sorry, I don't come here every day. I am from NE PA.
PostPosted: Thu Sep 13, 2012 6:35 pm
Superdrag,
I am from the outside of Reading PA, not sure what ur budget is but I have a brand new set of knarly offroad tires on new rims with adapters I will give u a great deal on them... I want them out of my garage. Prob is they r 29" I think Ground hawgs.
I will be in Trevorton this weekend I can bring them up if u want to meet me there.
Jim
PostPosted: Thu Sep 13, 2012 8:50 pm
I appreciate the offer, but I don't have any money to spend on something that nice.
PostPosted: Thu Sep 13, 2012 10:15 pm
I have Yokahoma tires on the front of my buggy that have that tread pattern. They were pushing in the mud so i used my grover to cut the treads out to have a full clean out paths. Work better however i will be removeing more over the winter.
