It is currently Sun May 03, 2026 3:39 pm
 Post subject: How should I cut these?
PostPosted: Mon Apr 09, 2012 4:14 pm
I finally got some v-treads. Can you guys draw me a picture of the best way to cut them? Hill climbuing and trail riding both.
Want me hold your purse so you can use the skinny pedal like a man?
PostPosted: Mon Apr 09, 2012 7:12 pm
the way i cut them is cut about an 1" out in the centers and then between the lugs cut'em to the cords and leave about 3/4 inch of rubber behind each lug and sharpen the lugs up
PostPosted: Mon Apr 09, 2012 7:15 pm
Just remember once you sharpen the front of the lugs you severly weaken them. Mine took two trips to lose two lugs on a fresh cut.....woooohoooo. So as long as you can afford to keep replacing them if they fail go buck wild! :mrgreen:
PostPosted: Mon Apr 09, 2012 7:38 pm
I cut every other set of lugs out and then went to the cords and man do they hook.
PostPosted: Mon Apr 09, 2012 8:27 pm
Been debating that wit my set. Sawzall for th lugz?
PostPosted: Mon Apr 09, 2012 10:20 pm
yeah I use a sawzall with a wood blade that i sharpened like a knife.
PostPosted: Tue Apr 10, 2012 8:46 am
Heres how i cut mine next step is every other lug like keven said..just not sure when i will get back to them...The last 2 are my 4ply stones 8) ImageImageImageImageImageImage
PostPosted: Tue Apr 10, 2012 10:45 am
The 45 degree tires are not the best however I found that if you put a 1" wide slot in the middle of each lug it improved traction a lot. Basically your doubling the number of griping corners.
PostPosted: Tue Apr 10, 2012 7:11 pm
I prefer the 45deg with off camber trail rides. When I had 23degs me rear slid around too easy. But I run a WC too.
PostPosted: Fri Sep 07, 2012 3:18 pm
Would these be a good candicate to cut? How much improvement do you get?
PostPosted: Fri Sep 07, 2012 8:14 pm
Just run um. That air cooled is going to have a hard time spinning them as it is. They wont wear to fast. You can take atleast 5 lbs of rubber off both tires which will help the engine move um.
