It is currently Sun May 03, 2026 12:48 pm
PostPosted: Fri Aug 05, 2011 12:27 pm
I have 31x15.5x15 v tread what size would you run for the street(tall)
PostPosted: Fri Aug 05, 2011 2:09 pm
i have ran 33x12.50 for years and they have worked good for me.
PostPosted: Fri Aug 05, 2011 5:45 pm
WB Competitor
same here...they worked good fof me to.
PostPosted: Fri Aug 05, 2011 9:43 pm
33x12.5 here as well with a stock 6 rib. I have had it to 90mph but its loud from the wind and spooks me because I built the front end, lol. But the gearing seams decent.
PostPosted: Fri Aug 05, 2011 9:47 pm
It really depends on what you want to do.. If you are looking to Race around tight turns and drag race off the lights, you will want to stay smaller.. If you want something you can use between trails, 31 - 33 would work best.
PostPosted: Sat Aug 06, 2011 8:08 am
he you go 36x17 goodyear..lolImage
PostPosted: Sat Aug 06, 2011 10:33 pm
I've been using 31/10.50/15 for 3 years and there fine. I've cruised at 70mph and ran to 90 in third at about 6500 rpm with a 4.83 gear. i am going to buy 33/10.50/15 to replace those soon.
PostPosted: Tue Aug 09, 2011 4:57 pm
I have to measure my rims that I have tires mounted on now and see how wide they are (rims were widened years ago by previous owner) I think I will stay with 31's but width will be an issue for the tire I want to put on these wheels.
PostPosted: Sun Aug 14, 2011 11:20 am
I have 16" wide rims (4lug) I think I will be looking for new rims and tires if I go to Wilwood disc's in the rear, anyone have any wheels and tires sitting around? :roll:
PostPosted: Thu Aug 18, 2011 5:01 pm
Ok, I am cutting down the wheels to 10" wide instead of 16". Then I plan on getting 31" or 33"tall for street mostly and some trail, the trans that I have is a reg. car trans. Will 33" be to much? What tires work well for both? Thanks
