It is currently Sun May 03, 2026 5:30 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: uncut firestones
PostPosted: Mon Jan 18, 2010 11:25 pm
giveitagallon wrote:
:roll: wow , thats plain as day after you said something you should say something to him dunebuggynut thats funny ! :lol: :lol:
You have no idea what I was thinking about posting over the trannys but all I could picture was PM's from moderators telling me enough is enough. Jokes like how many trannys does it take to screw your axle?......AH no...Ill stay off that one. BAD BAD BOY :wink: :wink: :wink:
PostPosted: Tue Feb 09, 2010 9:18 pm
well jeff did ya cut them ? if so how did they turn out ?
PostPosted: Wed Feb 17, 2010 7:33 pm
no not yet, i went up to dave's, but it was just to buy some mill tooling off of him... I think i might just order a head and blades for my uncles ideal 125 groover and use that instead of tieing up dave's cutter... i haven't had any time, jsut started a new job 3 weeks ago and i have school 4 nights week :( :(
PostPosted: Sun Mar 21, 2010 11:42 pm
hillaholic wrote:
Cut them like I told you, its a night and day difference. Afterburnt said we can use his cutter. Bring them over and we will get it done. It shouldn’t take long using a good cutter. We could even cut and grind the side walls so they look like my boggers if you want.
how much did you cut off the boggers? i want to do mine but i dont want to ruin a sidewall if i go too deep
PostPosted: Tue Mar 23, 2010 9:12 pm
http://www.woodsbuggy.com/index.php?opt ... =29&t=5436
those are brads hayshaker. we went out a bunch on them last year, even drove on one flat and the sidewalls are still holding. i think he has tubes too though. not sure.
PostPosted: Wed Mar 24, 2010 11:44 am
wow! that looks like a little much to cut off... i dont want to have to worry about poking holes in my side wall.. taking them to the cords is a little much for me.. my old man still dont understand how i can order a brand new $300 tire and start cutting them up...
when you guys sharpen the lugs what are you using? i guy i ride with found a blade for a wood router i'll see if i can find out which one exactly but it works good... also i got a 4 inch wood cutting blade and put it on a grinder works real good for shaving down boggers but is very scary! it could take your hand off real fast or junk a tire even faster... i'll get some pics of the blades tonight and try to post them
PostPosted: Wed Mar 24, 2010 8:07 pm
The thickness of the side walls very. Close to the lugs its about 1/2" and in the center of the side wall its a little over 1/8" then when you get close to the bead around 1/4".
