It is currently Mon May 04, 2026 6:51 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: aluminum front rims
PostPosted: Thu Jul 30, 2009 5:45 pm
RaceBugg1098 wrote:
True centerline wheels are rivited togather, the ones that are bolted are cms wheels. The centerlines are better, but both need beadlocks to hold up. I don't run beadlocks just to hold the tire on, I run them to re-enforce the wheel, and to keep from bending the edges. Once you beadlock a cms, it is just as strong as a centerline. Also, a 5 lug is WAAYY stronger than a 4 lug. :mrgreen:
the center line wheels and cms wheels are aluminum, are you using aluminum beadlocks and tig welding them on? if so where did you get them?
dave
PostPosted: Fri Jul 31, 2009 8:30 am
I tig them on, but I wouldn't be afraid to mig them. Drews has them in steel and alum. They are a top quality beadlock too!
