It is currently Sun May 03, 2026 3:32 pm
PostPosted: Sun Dec 07, 2008 1:10 am
I mounted the beadlock side and the tire was about 8” away from the non-beadlock side. The ether I had was more flammable than explosive. I went through an entire can of ether before I tried the carb and choke cleaner. This was the first try with the carb cleaner.
PostPosted: Sun Dec 07, 2008 1:57 am
great vid i think people should start making how to vids i think they would help alot
PostPosted: Sun Dec 07, 2008 10:17 am
It seems the either we buy on the shelf is very week compared to the our fathers bought. I will definatly replace either with carb cleaner from now on, thanks Brad!
PostPosted: Sun Dec 07, 2008 10:57 am
cool vid 8)
Mike
Got Honda?
PostPosted: Sun Dec 07, 2008 2:53 pm
I found out that If you take out the valve core before spraying with ether, the tire will not collapse as bad. The air is super heated and then cools off real fast.
Tony
Tony
PostPosted: Sun Dec 07, 2008 6:53 pm
This is the easiest way to do them, but I would rather use a ratchet strap to mount them, I wrapped mine around the tire and tighten them up and take the valve cord out if the valve stem and push the air hose all the way into the stem and it will pop them beads on, that way I don't have to worry about losing my eyebrows or letting the tire explode on me if I happen to put too much ether in it, you will never know. Cool video you made on the instructions though.
PostPosted: Sun Dec 07, 2008 10:57 pm
hahaha awesome brad... you can always count on brad to have ether and valve stems on the trail, not that i ever need them :roll: sweet vid man
PostPosted: Thu Jan 01, 2009 8:14 pm
Awesome video...brings back memories of a HummV wheel and tire flying through the night air in Ft. Erwin, CA...long story. Again, hats off on the video, more people should try to post them. It conveys so much more info than a description.
