It is currently Sun May 03, 2026 5:10 pm
 Post subject: bogger question
PostPosted: Wed Dec 03, 2008 11:18 pm
do they make a 4 ply
 Post subject: Re: bogger question
PostPosted: Thu Dec 04, 2008 4:17 pm
When I was researching them I did not see a 4 ply offered. Considering that they are for offroad trucks it does not surprise me.
PostPosted: Sun Dec 07, 2008 6:59 pm
Nope, they do not make them, like Odyknuck says they are for 4x4 trucks, they are very flexible when you cut the small lugs off of them and ground the sidewall down some, but I would recommend to use inner tubes if you do this, that way you don't have to worry about it leaking due to cutting the tire almost down to the belt and to benefit the way to help keeping the inner beads on if you are running beadlocks and to keep both beads on if not running beadlocks, they are dubbed to be the "inner beadlocks" according to some hardcore 4x4 rockbuggy drivers.
PostPosted: Mon Dec 08, 2008 11:19 am
ok thanks for the help its about time for me some new ones and thought if they did it would be good to get
