It is currently Sun May 03, 2026 5:49 am
 Post subject: bolting tires
PostPosted: Fri May 06, 2011 11:43 pm
what do yall use for the bolts and what do you do to make them stay in and hold air im thinking of doing this to some old buckshots
 Post subject: Re: bolting tires
PostPosted: Sat May 07, 2011 12:02 am
Hope you have a built trans and a good pp and clutch because they are not nice to that stuff.
PostPosted: Sat May 07, 2011 8:51 am
Kevin Thomas and Tony Kiley used evevator bolts with a barrel nut on the outside. the elevator bolt has a flat head that seals on the inside. Once you get the bolts and nut in and tight take a welder and tack the nuts on.
