It is currently Mon May 04, 2026 5:12 am
PostPosted: Wed Apr 02, 2008 5:24 pm
Engine Features
Single cylinder, SOHC, air-cooled, 4-stroke engine designed to produce smooth, usable power over a wide rpm range
Cylinder head features screw/locknut valve adjustment system for simplified maintenance, plus a link-plate-type cam chain and automatic tensioner to reduce mechanical noise
Power is enhanced by a MikuniTM BSR 29mm carburetor mated to a large capacity airbox and a specially tuned exhaust system for a throaty sound
Convenient electric start system with Start-In-Gear feature
Electric start system and CDI ignition are powered by compact maintenance-free battery with 150 watt charging system
Five-speed transmission with automatic clutch includes an easy-to-use reverse gear system - place the transmission in neutral - turn the fender-mounted knob and depress the shift lever
Low-maintenance shaft final-drive system is simple and reliable
Chassis FeaturesAggressive-styled bodywork similar to the LT-Z400 - includes high-clearance fenders, performance-inspired graphics and vertically-mounted halogen headlight
Wide, T-shaped seat combines comfort with a functional shape that allows the rider to easily shift his/her weight
Single 40/40W, body-mounted halogen headlight provides and exciting look and bright illumination - large 5/21W tailight/brake light combination is standard
Rugged steel-tube frame with standard steel skid plate and tube-type bumper
Independent double A-arm front suspension with preload-adjustable oil-damped shock absorbers - provides 6.1 inches of wheel travel for a comfortable ride over all types of terrain
Swingarm-type rear suspension features single shock absorber with five preload adjustments and 6.1 inches of rear wheel travel, plus 9.1 inches of ground clearance
Large diameter front disc brakes with single-piston pin-slide calipers and single cable-operated rear drum brake
Lightweight aluminum wheels and rugged tires (F: 22x7-10, R: 20x10-9), for high style and traction under a wide variety of terrain conditions
Serrated-type footpegs for high grip and comfort with additional built-in mudguard protection
Convenient, 5-liter water-resistant storage box
Large 2.8 gallon fuel tank with vacuum-operated fuel petcock
Price: $2,500
pics: http://s285.photobucket.com/albums/ll70/dunemandave/
PostPosted: Sun Jul 20, 2008 1:34 am
still 4 sale!
lowered price!
new pics!
PostPosted: Mon Jul 21, 2008 3:09 pm
What year is it? How many Hours on it. What size motor. Whats the lowest you will take.
PostPosted: Mon Jul 21, 2008 4:55 pm
it is 2008/i dont no the exact amount of hours on it but it was bought new and was not used alot/it is the Z250 Sry but that price is the lowest i will go i forgot to remove odo after i lowered it.
