It is currently Mon May 04, 2026 12:43 am
PostPosted: Sun Mar 03, 2013 11:03 am
Clean old 47 Farmall B. Been used since 2006 to drag logs and bush hob. Older restoration, newer head gasket, new manifold and muffler. Rear tires have calcuim and weights, good tires all hold air. Just started having carb problems. Runs good until it gets under a load and governor opens. When this happens, it runs lean, not getting enough fuel. Too many other projects. Sell for $1400. Located in Petersburg, KY. 8596300162
Cannot figure out how to post picture on here. Check out Cincinnati craigslist if interested. Type in Farmall in search.
