| Stub Axles, Car to Bus http://woodsbuggy.com/phpBB3/viewtopic.php?f=26&t=9893 |
| Author: | oddpowers [ Thu Jul 15, 2010 11:30 am ] |
| Post subject: | Stub Axles, Car to Bus |
Has any one machined off the lip of a car stub axle and redrilled and tapped it for a Bus CV? I have done this with mine, and it works. I am wondering how a guy could go about puting on another lip to help center the CV when you replace one in the woods. |
| Author: | chris38375 [ Thu Jul 15, 2010 11:51 am ] |
| Post subject: | Re: Stub Axles, Car to Bus |
we build our on stub axles,put a car in a lay and take the whole cup off then put the bus stub in there and cut it off,then weld the bus to the car,its free and it works,jus gotta get them same length as a stock car stub |
| Author: | turboblue [ Thu Jul 15, 2010 2:03 pm ] |
oddpowers wrote: Has any one machined off the lip of a car stub axle and redrilled and tapped it for a Bus CV? I have done this with mine, and it works. I am wondering how a guy could go about puting on another lip to help center the CV when you replace one in the woods. Sell you a set Troy. Then you can see how it's done....... |
| Author: | oddpowers [ Thu Jul 15, 2010 3:08 pm ] |
Quote: Sell you a set Troy. Then you can see how it's done....... How bout you just send me some pics of them insted |
| Author: | turboblue [ Thu Jul 15, 2010 3:39 pm ] |
oddpowers wrote: Quote: Sell you a set Troy. Then you can see how it's done....... How bout you just send me some pics of them insted Sure......I have your CC number on file........ |
| Author: | Andrew_Ha [ Thu Jul 15, 2010 7:24 pm ] |
I have bus stubs drilled out to take car cv so I can use a car in a pinch |
| Author: | rockrockets1 [ Fri Jul 16, 2010 6:51 pm ] |
Now that's using your head Andrew_Ha wrote: I have bus stubs drilled out to take car cv so I can use a car in a pinch
| Author: | A. Cole [ Sun Jul 18, 2010 9:03 pm ] |
chris38375 wrote: we build our on stub axles,put a car in a lay and take the whole cup off then put the bus stub in there and cut it off,then weld the bus to the car,its free and it works,jus gotta get them same length as a stock car stub Hope your a great welder, thats alot of stress!! Redrilling sedan for bus is really common. I've hade some with a ring welded on and seen lots that had no ring. |
| Author: | chris38375 [ Sun Jul 18, 2010 10:03 pm ] |
A. Cole wrote: chris38375 wrote: we build our on stub axles,put a car in a lay and take the whole cup off then put the bus stub in there and cut it off,then weld the bus to the car,its free and it works,jus gotta get them same length as a stock car stub Hope your a great welder, thats alot of stress!! Redrilling sedan for bus is really common. I've hade some with a ring welded on and seen lots that had no ring. been running the same stub axles for 5 yrs,and we ride nearly every weeknd,and we do some ridin and playin,jus ask anybody that has rode her its some rough ridin,dammnit i hope u didnt jinx me,,gonna have to carry a spare now,,,lol |
| Author: | turboblue [ Mon Jul 19, 2010 11:27 am ] |
Andrew_Ha wrote: I have bus stubs drilled out to take car cv so I can use a car in a pinch Your using a bus torsion I take it. |
| Author: | A. Cole [ Mon Jul 19, 2010 5:57 pm ] |
chris38375 wrote: ,dammnit i hope u didnt jinx me,,gonna have to carry a spare now,,,lol Sorry |
| Author: | Andrew_Ha [ Mon Jul 19, 2010 7:32 pm ] |
turboblue wrote: Andrew_Ha wrote: I have bus stubs drilled out to take car cv so I can use a car in a pinch Your using a bus torsion I take it. Not sure on torsions but arms r beefed up stock arms |
| Author: | A. Cole [ Mon Jul 19, 2010 9:10 pm ] |
Andrew_Ha wrote: turboblue wrote: Andrew_Ha wrote: I have bus stubs drilled out to take car cv so I can use a car in a pinch Your using a bus torsion I take it. Not sure on torsions but arms r beefed up stock arms Sounds like you have car stubs that were drilled for bus and a ring added. If your axle nut is 36mm its a car stub. |
| Author: | volksdude2007 [ Tue Aug 10, 2010 8:26 pm ] |
i used the car stubs that were drilled out i was not pleased with them the walls were too thin and even the one with a ring welded on the outside was week i kept shearing bolts off when i would get on it or the tire would take a jolt then it just started pulling the bolts out of the stub i think i just had a bad set though wasnt done correctly or something |
| Author: | A. Cole [ Tue Aug 10, 2010 8:46 pm ] |
volksdude2007 wrote: i just had a bad set though wasnt done correctly or something yes |
| Author: | oddpowers [ Wed Aug 11, 2010 10:27 am ] |
Quote: i used the car stubs that were drilled out i was not pleased with them the walls were too thin and even the one with a ring welded on the outside was week i kept shearing bolts off when i would get on it or the tire would take a jolt then it just started pulling the bolts out of the stub i think i just had a bad set though wasnt done correctly or something I haven't had any problem with mine. I just would like to have some kinda ring around it, to make it easier lining up the bolts if I ever break a CV. |
| Author: | turboblue [ Wed Aug 11, 2010 12:09 pm ] |
volksdude2007 wrote: i used the car stubs that were drilled out i was not pleased with them the walls were too thin and even the one with a ring welded on the outside was week i kept shearing bolts off when i would get on it or the tire would take a jolt then it just started pulling the bolts out of the stub i think i just had a bad set though wasnt done correctly or something I've sold many sets of these and never an issue. Sounds like your were made out of concentric. |
| Author: | volksdude2007 [ Wed Aug 11, 2010 5:53 pm ] |
well i seemed to have sorta called these shit and didnt realize i was just refferring to the set i had i know a few people that has ran these since i was little kid and still do to this day with out a problem sorry about that in a way i wish i had a set of these redrilled ones that were in good shape i had quite a few car cvs but gave them all away when i switched to the chromoly bus stubs |
| Author: | Griffin [ Wed Aug 11, 2010 11:39 pm ] |
A. Cole wrote: Sounds like you have car stubs that were drilled for bus and a ring added. If your axle nut is 36mm its a car stub. 924/thing stubs also use 36mm axle nuts but have the bus pattern on them. |
