It is currently Sun May 03, 2026 10:30 pm
 Post subject: my 2x3 arms build
PostPosted: Fri Apr 30, 2010 7:30 am
i finley got to start building my new arms its time to get this thing moveingImage
 Post subject: Re: my 2x3 arms build
PostPosted: Mon May 03, 2010 5:26 pm
thats sweet. Are you going to put anymore bracing in there? Kinda gets me motivated to start mine.
PostPosted: Mon May 03, 2010 6:10 pm
no i built a pair about 7 yrs ago just like these same jig never bent one or cracked one hit alot of trees sold them with my buggy had to build a new set for my baja
PostPosted: Mon May 03, 2010 6:27 pm
where you from?
PostPosted: Mon May 03, 2010 6:57 pm
im in indianapolis in
PostPosted: Mon May 03, 2010 9:21 pm
damn wish we were closer. Id rent that jig from ya.
PostPosted: Mon May 03, 2010 10:26 pm
blind chicken raceing shows and tells how to make a jig its real easy to make mine is made from scraps laying around the shop and you can make your own designs if i can help just hit me up
PostPosted: Sun May 09, 2010 4:41 pm
when you set the jig up, the arms are left or right correct? do you shim any angle into the bearing housing for any reason? just curious
Lifes journey is not to arrive safely at the grave in a well preserved body but to slide in worn out screamin WOW WHAT A RIDE!!
PostPosted: Sun May 09, 2010 9:00 pm
i set the bearing housing at no angle at all and correct they are left or right i put mine on and set every thing level and the cv are at 19.5 degrese and are smooth jacked off the groundImage
PostPosted: Fri Aug 27, 2010 12:06 am
looks good alot of fing around to get to that ha good luck awsome baja
This one time at wellsville
