PostPosted: Mon Oct 19, 2009 10:44 pm
Wanting to find one of these. Got my bender going. Got my welder running. But tired of using a grinder and cut off wheel. :? So who has some recamendations?
PostPosted: Mon Oct 19, 2009 10:53 pm
All I can tell you is the Harbor Freight one will last Maybe long enough to do one frame, if your lucky. Same as anything else, you get what you pay for. I use a lathe to notch my tube, works every time.
PostPosted: Tue Oct 20, 2009 12:08 am
mike, maybe I'm just tired and not thinking right, but how do you notch the tube with a lathe? I could see using a mill and the correct size holesaw working nicely, but I'm not sure how to do it on a lathe? I'm probably overthinking it.
PostPosted: Tue Oct 20, 2009 6:53 am
Chuck up a 1 1/2" end mill in the chuck, I made a V-block that goes where the tool holder lives. Set the compound to the angle you want and have at it.
PostPosted: Tue Oct 20, 2009 7:03 am
jd2 tube notcher
http://cgi.ebay.com/JD2-Notch-Master-Tu ... 563617a915
I bought the harbor freight notcher an modified it to what I wanted.
PostPosted: Tue Oct 20, 2009 7:27 am
Wow, with the shipping thats more then my bender!!
PostPosted: Tue Oct 20, 2009 7:06 pm
Well this 1 here is $600. I bought my harbor freight for $50 and for that price I dont fell bad about modifying it how ever I like.
http://www.syncnotcher.com/purchase.html
PostPosted: Tue Oct 20, 2009 7:16 pm
Well the cutoff wheels work fine, lol. Just takes a while. I uste that tube miter program to draw it out and been real happy so far.
PostPosted: Wed Oct 21, 2009 9:48 am
like he said earlier harbor freight is junk but in this case i think their notcher is worth the 50 bucks. iv rebuilt my frame almost entirely twice now and it's still holding up.
http://www.harborfreight.com/cpi/ctaf/d ... mber=42324
I built a small stand for mine and use a hand drill instead of a drill press.
PostPosted: Mon Oct 26, 2009 1:46 am
I recently bought a notcher from a local tool jober that looks like the Harbour frieght model. First thing I had to do was shim the vise 1/8" to line it up with the hole saw center. and correct the 90* base plate to 90*. It may be Chinese, but it does work pretty sweet.
PostPosted: Mon Oct 26, 2009 9:34 am
Plasma cutter works pretty good in combo with my 1" burr in the die grinder.
PostPosted: Mon Oct 26, 2009 1:09 pm
Trying to avoid another high 3 digit expence.
