It is currently Sat May 02, 2026 7:11 pm
PostPosted: Tue Feb 03, 2015 9:13 pm
I was looking at my recently acquired buggy and thinking something just doesn't look right with it. I was thinking maybe a hood might make it look a little more complete. Here's is a quick drawing I whipped up.
The yellow lines are showing tubing for a frame. Then I was just going to cover that with the appropriate sheet metal. But to keep from making it just square I thought I would weld my main down tubes on the inner sides of the windshield lights from the lower windshield frame to the front bumper. That would make the sides of the hood come down at an angle. I would need to make two patches at the windshield indicated by the pink arrows. And then I would also fill the areas near the front wheels.
If my picture is too small I can make it a little bigger.
So what do you folks think of my plan? Will it look OK or will it look cobbled up? And that is of course assuming that I do good welds and body work...lol
Greg
Street legal 4 seat buggy.
Packrat frame
1915 CC engine (I think)
3 rib tranny
My first "real" rail buggy...lol
PostPosted: Tue Feb 03, 2015 9:42 pm
Yeah, it's possible.
PostPosted: Wed Feb 04, 2015 4:00 pm
love my hood.
PostPosted: Wed Feb 04, 2015 9:38 pm
I did not build my buggy but I am extremely impressed how well the wiring harness fits Under the hood
PostPosted: Wed Feb 04, 2015 9:43 pm
Thanks for the replies and pictures. Exactly what I wanted to see and hear. It'll take me a while to get it done but I'll start gathering materials as I can. I'll probably use some 1" pipe for the frame since I already have it. Heck know that I think about it I'm pretty sure I've got some aluminum sheeting behind the barn. May not take as long as I was thinking. Lol
Packrat frame
3 rib tranny
PostPosted: Thu Feb 05, 2015 8:46 am
My hood is made of sheet metal rather than aluminum. it does NOT have any sort of frame under it and is quite strong. I can stand on it. It hinges at the front so it opens for easy access.
PostPosted: Thu Feb 05, 2015 10:44 am
Big rd sign works good also
PostPosted: Sun Jan 24, 2016 11:32 pm
I've put a hood on my rail, but I added some 1"conduit for a frame for it. The larger horizontal frame tube that was there was a bit too low for my taste. And since I can't seem to make anything simple for myself, I added a separate forward section from the 1" round tube and some 1"square tubing (split into a shallow "C" channel edges). I used a heavy duty piano hinge in the middle so it opens like a regular hood. The forward opening part gives me access to the battery box, steering box and tie rods as well as the reservoirs for the brakes and clutch. I also added some hydraulic lift cylinders from the JY, just because I had a few pairs of them laying around.
BEFORE:
During the build:
AFTER:
Hydraulic lifts:
It's all just an exercise in futility though as this frame is tweaked pretty badly. The twist can be seen with the naked eye in the 3rd pic, as well as the next to last pic above. What the pics don't show is the front axle beam is also bent back noticeably. The beam is welded to the frame, and from the looks of it, was probably bent BEFORE the PO welded it to the frame. :roll: At least I learned a lot about how to make a body and hood from it. I'm planning on replacing the frame with a Beeline Pack Rat 2 seater kit later this year. I'll put that knowledge and experience to good use when I build the Pack Rat frame.
Here's a link to the build threads if anyone is interested.
http://www.thesamba.com/vw/forum/viewtopic.php?t=629493
or there's a condensed version here.
http://shoptalkforums.com/viewtopic.php?f=28&t=147561
PostPosted: Mon Jan 25, 2016 8:19 am
Wouldn't bother with the little tubes down the side, just put a cross in and work over that:
