It is currently Sun May 03, 2026 8:49 pm
 Post subject: Needs bag pic's
PostPosted: Sun Dec 28, 2014 7:22 pm
I've looked threw the ones that I could find on here. Maybe there is a few I haven't seen. Or a little more info ab the bottom mount "pivoting". Is that something major bc some look like they don't have them. And is there a certain angle or spot they need to be mounted. It can't be that hard to do just wanna do it right and get 100% advantage outta the bags.
 Post subject: Re: Needs bag pic's
PostPosted: Sun Dec 28, 2014 8:59 pm
Here are ones I saved from mad mikes build. ImageImageImageImageImageImageImageImageImage
PostPosted: Sun Dec 28, 2014 9:02 pm
Damn, quite the collection ya got there. 8)
PostPosted: Sun Dec 28, 2014 9:16 pm
My phones have 1000's of buggy picks for reference lol
I was considering airbag at one point.
PostPosted: Sun Dec 28, 2014 9:43 pm
Im just trying to think of a easy way to do a pivot mount
PostPosted: Sun Dec 28, 2014 9:50 pm
All I'll say is, if that isn't built and installed right, it will not work.
PostPosted: Sun Dec 28, 2014 10:55 pm
I tried to fabricate lower pivot mounts, not machine, and they were pretty good but it didn't work, bag would flop one way or the other, I would say there not needed but it would definitely help prolong the life of the bags, if you want pivots I'd have madmike or someone machine a set, if not don't over think it and just mount them, I wasted a lot of time messing with those pivots and ended up welding them so they don't pivot lol
PostPosted: Sun Dec 28, 2014 11:11 pm
That's what I'm thinking. Just mount them and be done. Thanks for the pics
PostPosted: Mon Dec 29, 2014 6:23 pm
Here is what I did works good. I had it just mounted as you can see by the big base. Rode like sh*t. Change to the way I have it now world of differents. I would not even try to put bags on any other way now.
PostPosted: Mon Dec 29, 2014 8:08 pm
The set up Mike built looks to me ( me not knowing much) would be the way to go .By letting the bag pivot looks like it would cycle more in a direct line thus making it much more efficient.JMO .And the stuff Mike builds is just rugged,bad ass stuff.
PostPosted: Sat Jan 24, 2015 10:59 pm
Has anyone really ran lower pivots a long time ??
I would think they just need to pivot a a few degrees.
Why do y'all think ??
Is the bag stiff enough to keep themselves straight ??
I've got 4 #3800's in a box waiting to find the time to install.
Or should I just mount them so they are straight at mid travel ??
PostPosted: Mon Jan 26, 2015 3:29 pm
We've ran them seversl years now on a ac buggy and 1 year on a wc buggy. Had a lil problem with the wc one with the bag folding forward if I ran to low of air pressure. Made slots on the bottom mount to center the bag perfect and it works fine
PostPosted: Mon Jan 26, 2015 3:34 pm
Ac only has 3"over arms and the wc has 6"over. I think the extra travel plays a part in it
PostPosted: Mon Feb 09, 2015 11:47 pm
I have only installed bags on 2 buggies, but after talking to bag manufactures and trying a lower pivot, I have learned to install them as vertically as possible and forget the lower pivot. The lower pivot creates far more problems than it solves. I have used bags on 5x5 arms and stock arms, the only way I have found to make them work well is with solid lower and upper mounts.
Good Luck
Kenric
