Frame Horn Bungs
http://woodsbuggy.com/phpBB3/viewtopic.php?f=26&t=16704
Author:  UncleJerm76 [ Sat Feb 22, 2014 11:14 pm ]
Post subject:  Frame Horn Bungs
I'm having a hard time finding some frame horn bungs, the kind you would use if your making your own tubular frame horns. Anyone know where I can find a pair? What are you guys using if they aren't available - just welding in some Grade 8 nuts?
Author:  Red Barron [ Sun Feb 23, 2014 4:30 am ]
Post subject:  Re: Frame Horn Bungs
I always cut them off a junk torsion. But a grade eight nut would work
Author:  UncleJerm76 [ Mon Feb 24, 2014 1:55 pm ]
Thanks Barron, looks like "Ace is the place with the helpful hardware..."
Author:  RaceBugg1098 [ Tue Feb 25, 2014 12:19 pm ]
just use some 2 bolt flanges. I weld the rear bottom mounting plate to the tubes. You dont really need to remove it anyway.
Author:  UncleJerm76 [ Tue Feb 25, 2014 10:08 pm ]
No need to weld the plate to the horns, I like being able to remove it with my engine and trans as one unit. But a two bolt flange on each side isn't a bad idea at all. Especially if I combine it with a smaller short inner tube as a guide. Thanks
Sent via TapaTalk
Author:  UncleJerm76 [ Fri May 09, 2014 10:42 am ]
Post subject:  ISO Frame Horn Bungs
Looks like I'm still stuck on trying to find two frame horn bungs - aka weld-in nuts. Once I get an idea in my stubborn head its really hard to change it LOL. So if anyone has two stock Frame Horn Bungs in good shape (not cross-threaded) for sale please let me know. I will post in the Classifieds too, but wanted ask here since I already had this thread going about the topic. I will post back here when I no longer need them.
