It is currently Sun May 03, 2026 2:52 pm
 Post subject: Thru rods
PostPosted: Wed Nov 20, 2013 7:44 am
I've been trying to research the thru rod setup is it actually a soild all thread type rod that goes thru the beam or could someone explain to me how they work maybe with some pics
 Post subject: Re: Thru rods
PostPosted: Wed Nov 20, 2013 9:12 am
There is a stack of flat springs that are stacked in such a way to form a square. The end of your arms have that square. Those rods go all the way through from one side to the other with a set screw on the end of each arm. The thru rods are round bar stock with nuts on the end. Thus they don't get fit the square in your arm so the arms just rotate on the rods. The nut keeps the arms from coming off. No torsion springs (flat bars) means you have to run coil or air shocks.
PostPosted: Wed Nov 20, 2013 10:41 am
So if that's the case widening the beam would be fairly easy thanks for the info
PostPosted: Wed Nov 20, 2013 10:53 am
Here is a pic with the Thur rods pulled half way out of beam, if that helps
PostPosted: Wed Nov 20, 2013 9:47 pm
Yeah that picture is very helpful do they seem to hold up to a lot of abuse and what size should I run 1/2 or 5/8
