It is currently Mon May 04, 2026 9:32 pm
PostPosted: Fri Mar 30, 2012 5:18 am
Need to know year that this may have come on(if any) or bearing numbers . Much thanks for any help.
PostPosted: Fri Mar 30, 2012 10:27 am
Call pipedope I think he knows the answer to this ( maybe) and if not tell him to hug a root cause he should know,lol. Chad :mrgreen:
PostPosted: Fri Mar 30, 2012 12:57 pm
'67 came with wide 5 balljoint hubs.
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Fri Mar 30, 2012 1:11 pm
Yeah but the 67 spindles are smaller then the newer balljoint spondles.
PostPosted: Fri Mar 30, 2012 2:39 pm
VW Things will work.
PostPosted: Fri Mar 30, 2012 2:57 pm
Just get late balljoint spuds and weld em on.
-Dakotah/koko
PostPosted: Fri Mar 30, 2012 7:40 pm
That what I have, late ball joint spuds welded to king pin. Thing bearings I think is what I need. Thank u all for the help.
PostPosted: Fri Mar 30, 2012 8:49 pm
Front inner bearing type 1&3,69-on #311-405-625B
Front outer bearing type 1&3,66-on#311-405-645
front wheel seal type 1&3,66-79 w/disc brake #321-501-641
This is for late model hubs.
Not sure this is what you need if you got wide 5 hubs.
Ou made need front inner bearing type 1&3,66-68 #311-405-625
front outer bearings the same.
Front wheel seal type 1 66-6/68 #131-405-641A
Hope this helps. Chad :mrgreen:
PostPosted: Fri Mar 30, 2012 9:26 pm
I have 311405625 and 311405645 both to small. Thanks for looking though
PostPosted: Sun Apr 01, 2012 12:31 pm
Smitty, I did this before. I just took some of the 5 lug bearings and some of the 4 lug bearings and made it work, but I don't have the numbers. Im sure I used the bearings off the balljoints and the cups off the kingpin. Roller to cup angle might not have matched perfectly, but I never had an issue and I ran them on and off road for probably 2 years this way...
PostPosted: Thu May 03, 2012 10:31 am
get a drum brake 65 and older type 3. they use the fat shaft newer roller beetle bearings and have that nice "star spoke 5 lug design".
