PostPosted: Sat Apr 09, 2011 6:19 pm
I have to widen the frame for accept the dual carbs, My idea is to basically just bubble the frame in a 1 foot section But im not sure if i should try to find 90 degree corner pieces to make it, or just bend one piece like a half moon Any input would be appreciated. Thanks
"IT IS WHAT IT IS"
PostPosted: Sat Apr 09, 2011 8:40 pm
Don't they make different intakes for tight spots that don't take as much room
PostPosted: Sat Apr 09, 2011 10:19 pm
I am probably reading this wrong but dont you mean bubble out?
PostPosted: Sat Apr 09, 2011 11:43 pm
I had to bubble my frame out on the back around the carbs and it worked great, even looks good. I think you can see it on my build thread. Its on page 4 of the well here goes thread under buggy builds, check it out. :)
PostPosted: Sun Apr 10, 2011 7:53 am
on my old buggy I made a foot on a pipe and welded it to a car jack and heated on booth sides of the foot then pushed it apart. worked good for me.
PostPosted: Sun Apr 10, 2011 10:53 am
Yea, mickey I meant bubble the frame out- In a foot secton of it lol. Anyone have a measurement of how wide it is from carb to carb? it would be cool to get this done before the carbs get here soi can juss bolt"m on and get to adjusting.
"IT IS WHAT IT IS"
PostPosted: Sun Apr 10, 2011 5:12 pm
I would wait untill you have Carbs in hand before making mods to the frame.
PostPosted: Sun Apr 10, 2011 8:47 pm
Yea, davehix give me some measurements earlier, But I decided Im gonna go riding this weekend, then switch it over that way I can see how big of a difference they really make. Cuz i havent been riding for awhile
"IT IS WHAT IT IS"
PostPosted: Mon Apr 11, 2011 12:24 pm
if i got you right, you want to bend a peice of tubing like how you would see a peice of conduit passing over another conduit? thats a difficult bend with 1.5" tubing in a 12" legnth! Ya might be better off tryin to miter it (cut 2 45*s)
PostPosted: Mon Apr 11, 2011 12:28 pm
Hows about a big radius 180 deg bend on each side to make the proper width? I have a 6.5" CLR die for my JD2 bender.
PostPosted: Mon Apr 11, 2011 2:04 pm
Im not really sure what would be best, The ideal thing to do would be take the buggy to someones house that has a bender and figure it out that way. I did the measuring i need approx. 4 inches on each side.
"IT IS WHAT IT IS"
PostPosted: Mon Apr 11, 2011 2:05 pm
But davehix brought up a goodidea to me, The piece hillaholic made as reverse treebars would pry work just fine, weld them on then cut out the section of existin frame.
"IT IS WHAT IT IS"
PostPosted: Mon Apr 18, 2011 12:23 am
I found these they are juss grab handles to weld on, But Basic Idea of what im wanting to do too widen the frame.Image
"IT IS WHAT IT IS"
PostPosted: Mon Apr 18, 2011 1:56 am
i think i like the bottom 2 if i were to have to do something like that
PostPosted: Mon Apr 18, 2011 10:08 am
Same here, I dont want it to look chopped up, Want it to have a nice flow to it like its always been that way Ima try a couple different things today, My one friend has a bender But only has a 1 3/4" die or whatever So we're gonna try a piece of that and see how it looks.
"IT IS WHAT IT IS"
PostPosted: Tue Apr 26, 2011 1:54 am
If your frend has a spare piece of the 1 3/4 tube, bend it, then cut it in half lenght wise and sleeve the dies.
I sleeved my 1 1/2 " tube dies to bend 1" sch 40 pipe. ( Tree bars ) Worked great.
PostPosted: Tue Apr 26, 2011 5:04 am
I got it all finished up turned out nice, post a pic of it later today.
"IT IS WHAT IT IS"
PostPosted: Fri May 13, 2011 7:04 pm
so where is the pix!
