It is currently Sun May 03, 2026 12:02 pm
 Post subject: Axle lengths
PostPosted: Sat Nov 30, 2013 1:32 pm
Ok on my buggy I'm running the bus torsion but I swapped in some beetle trailing arms I measured from from inside my stubs to inside tranny cv cups I got 18.25 inches i can't seem to find no axles that size there either 17.5 or 18.75 am I missing something here any help would be sweet thanks
 Post subject: Re: Axle lengths
PostPosted: Sat Nov 30, 2013 1:44 pm
I always set suspension so flanges are straight across from each other. Measure inside to inside. then subtract 1/4 from total length. You will also want to ck them at full droop.
PostPosted: Sat Nov 30, 2013 1:56 pm
The 18.25 was straight across at full drop my stock 18.75 are good there is minimal splines so I can't trim them
PostPosted: Sun Dec 01, 2013 11:25 am
I needed 17" axles, had to buy 17.5 and cut them down. The aftermarkets have around 3" of splines. Appletree is having a sale until Dec. 2. I saw some up to 40% off.
PostPosted: Sun Dec 01, 2013 8:11 pm
X 2
