It is currently Sun May 03, 2026 4:38 pm
 Post subject: Lincoln Diff
PostPosted: Wed Sep 26, 2012 9:33 pm
Lincoln Mark VIII with a 4.6 four valve, 1993 . I went to pull a part and this car had a 3.07 ALUMINUM 8.8 IRS diff. I loosened it up and it clunked to the ground instead of a common ground shaker with an iron diff.The iron diff out of a nearby 4.6 cougar has an 8.8 327:1 diff. I snatched the aluminum! It will be in the Passsat this week end.It will be a little higher ratio but maybe it will chug the wheel speed down a little.
 Post subject: Re: Lincoln Diff
PostPosted: Wed Sep 26, 2012 9:47 pm
I will see this monster at the event but could you post some photo's. I find others engineering intriguing.
PostPosted: Wed Sep 26, 2012 9:54 pm
hope to buy a new camera this week.It will be next week before I get anything posted.
PostPosted: Thu Sep 27, 2012 11:01 am
x2
I'm addicted to brake fluid......but I can stop at any time
PostPosted: Thu Sep 27, 2012 3:15 pm
Whenever someone sees it take pictures. I'm intrigued by this concept.
PostPosted: Thu Sep 27, 2012 4:51 pm
so with this setup whats going to be the weekest link now?
PostPosted: Thu Sep 27, 2012 6:56 pm
My guess is CV's and axles. I would think it would be pretty stout. Worst case is you have to find another differential for a few hundred. Not bad compared to a couple thousand for transaxles.
