It is currently Sun May 03, 2026 12:07 pm
 Post subject: New rear trailing arms
PostPosted: Thu Jan 12, 2012 12:06 am
What do yall think? Me and a friend of mine just got done buildin them, they are 3x3s.
http://i1137.photobucket.com/albums/n51 ... ngarms.jpg
PostPosted: Thu Jan 12, 2012 5:42 am
Maybe a couple gussets where the spring plate bolts is welded. What thickness is the tubing?
PostPosted: Thu Jan 12, 2012 6:27 pm
I think it is 1/4 it's 2/3 tubbing
PostPosted: Sat Jan 14, 2012 9:17 am
id bend those in a heart beat.
PostPosted: Sat Jan 14, 2012 11:49 am
Southern Buggys / WB Sponsor
If your going with that style i would weld a strap around or partially around the pivot bolt tubing, looks like i saw a few places around your bearing pocket that could have been plated to creat a gusset. If you want to make the 2X3 stoughter try getting you some angle welded on the front or back in the same manner we do our tree bars. Just keep in mind the clearance you will need for CVs.
PostPosted: Sat Jan 14, 2012 6:40 pm
I would say those won't take much abuse around the bearing housing,needs to have more bracing IMO.and maybe also around the spring plate bracket.just think they could use a little more beef.Chad :mrgreen:
PostPosted: Sun Jan 15, 2012 12:51 am
These are about the same arms that im running now and they seem to hold up well. Thanks for the input.
PostPosted: Sun Jan 15, 2012 12:56 am
We welded an piece of flat bar all the way around pivot bolt tubing, Will be running bus cv's should have plenty of clearence.
Thanks
