It is currently Sun May 03, 2026 12:07 pm
PostPosted: Sat Dec 24, 2011 4:17 pm
I've been looking for a bender... All the cheap ones only bend 90 degrees. Pro Tools dies are 120 degrees and have a build your own model that looks like it should be pretty reasonable to put together with their free plans.
http://www.pro-tools.com/200k.htm
PostPosted: Sun Jan 01, 2012 9:10 pm
Call Nick or you can uses my bender
PostPosted: Sun Jan 01, 2012 10:26 pm
Adam, it's Dave. You can use mine also it will bend 180
PostPosted: Mon Jan 02, 2012 3:36 pm
I started making it... I told Nick if it doesn't work out I'll be heading his way, or yours :D He told me you picked up a speedway model. I was looking into the speedway style but it max's @ 90 degree. We'll see how it turns out :?: Thanks Kevin.
PostPosted: Mon Jan 02, 2012 3:37 pm
Thanks Dave... Hopefully mine will work out.
