It is currently Sun May 03, 2026 4:38 pm
PostPosted: Wed Dec 07, 2011 6:10 pm
What do you guys recomend to clean tube before welding? I remember the thread we had stating do not use brake cleaner, but not what to use.
PostPosted: Wed Dec 07, 2011 7:11 pm
Acetone gets the oil off and evaporates immediately.
PostPosted: Thu Dec 08, 2011 1:22 am
i would say acetone. I use brake cleaner but make sure that it does not have any tetrachloroethylene in it. That is the chemical that creates the harmfull chlorine gas that was mentioned in that post. Most of the NON-flammable brake cleaners have tetrachloroethylene. But if you want to be safer.... I would say acetone.
PostPosted: Thu Dec 08, 2011 9:12 am
Well the type I use says NO-CHLORINE! So its ok to use?
PostPosted: Thu Dec 08, 2011 1:06 pm
I just sand off the area to be welded by hand with some 120 grit. Thats for MIG or TIG. Works fine for me :mrgreen:
PostPosted: Thu Dec 08, 2011 11:28 pm
RaceBugg1098 wrote:
I just sand off the area to be welded by hand with some 120 grit. Thats for MIG or TIG. Works fine for me <img src="http://www.woodsbuggy.com/plugins/system/yvsmiley/phpbb/icon_mrgreen.gif" alt="Mr. Green" class="yvSmiley">
Yea,what he said. Whats all the fuss? If its new pipe, just weld it! Its just a woodsbuggy :lol:
PostPosted: Thu Dec 08, 2011 11:56 pm
CLEAN . NAIL IT .
PostPosted: Fri Dec 09, 2011 2:44 am
When i cut it with the tube notcher i use wd40. Just wanting it clean for a good weld.
PostPosted: Fri Dec 09, 2011 1:10 pm
I just wipe it off and weld. The only time I have a problem is when building a frame or any bigger project that I tack up and it may sit for a week or so before I weld it out, all the cutting oil runs out the bottom right where I need to weld. Then I blow it off real good with air comp and wipe it down.
