| giveitagallon buggy build http://woodsbuggy.com/phpBB3/viewtopic.php?f=23&t=8019 |
Page 1 of 2 |
| Author: | giveitagallon [ Fri Nov 06, 2009 10:27 pm ] |
| Post subject: | giveitagallon buggy build |
here are some pics of my buggy im trying to learn the photo bucket thing so be patient , ill update as i go
| Author: | giveitagallon [ Fri Nov 06, 2009 10:35 pm ] |
| Post subject: | Re: giveitagallon buggy build |
i cut the top frame rails off and replaced them to get the king pin front end in her .
| Author: | plumberbill [ Sat Nov 07, 2009 9:45 am ] |
nice job on the shock towers, i see a set of fox air shocks and extended front trailing arms in your future on your photobucket right below where it says "upload videos and images" click on more options and change your photo size to large 640x480 |
| Author: | dunebuggynut [ Sat Nov 14, 2009 2:06 am ] |
You got the Photobucket thing figured out pretty well. I never tried it till yesterday either. Your rear shock mounts gave me an idea for mounting mine. Ill have to see if that type of mount will work out back. |
| Author: | giveitagallon [ Sun Nov 22, 2009 1:54 pm ] |
we did a little bending over the weekend , turned out good i think, next is to build the x brace !
| Author: | MickeyMouse [ Sun Nov 22, 2009 2:31 pm ] |
plumberbill wrote: nice job on the shock towers, i see a set of fox air shocks and extended front trailing arms in your future on your photobucket right below where it says "upload videos and images" click on more options and change your photo size to large 640x480 It is looking great. If you decide to add extended front trailing arms you will probably need to move your steering box to the center. The passenger side tie rod usually hits the frame with the steering box to the side. A lot of people go right to Rack and Pinion but I would try to remount the steering box before going to Rack and Pinion. |
| Author: | giveitagallon [ Sun Nov 22, 2009 9:56 pm ] |
THANKS FOR THE FYI MICKEY MOUSE , TO ME THE CAB WAS WAY TO OPEN MADE ME A LITTLE UNCOMFORTABLE SO I MADE THOSE BARS TO CLOSE IT UP A LITTLE , MAN ITS REAL COMFY NOW NEXT IS THE X BRACE AND COOLER RACK BEHIND THE SEATS ! THE X BRACE WONT BE TO BIG JUST ENOUGH TO SAFE HAVEN THE BEER COOLER ON A ROLL ! |
| Author: | giveitagallon [ Tue Feb 02, 2010 10:22 pm ] |
pics the x brace i added . ![]()
| Author: | giveitagallon [ Tue Feb 02, 2010 10:29 pm ] |
| Author: | giveitagallon [ Tue Feb 02, 2010 10:37 pm ] |
b een playin around building some front arms . ( thanks afterburnt for the help !)
| Author: | giveitagallon [ Fri Apr 16, 2010 10:15 pm ] |
th e gearbox mount front arms finished and on ![]() ![]() ![]() ![]() gearbox is off a jeep cherokee and all the tie rods and sleaves and steering shaft , the power steering pump will be off a geo tracker this is a copycat setup from afterburnts rail and again thanks dave
| Author: | davehix [ Fri Apr 16, 2010 11:17 pm ] |
looking good!!!! |
| Author: | plumberbill [ Sat Apr 17, 2010 9:17 am ] |
looking good.......git-r-done |
| Author: | giveitagallon [ Wed Dec 08, 2010 10:50 pm ] |
a lot of changes over the summer but here is what she looks like now . |
| Author: | giveitagallon [ Wed Dec 08, 2010 11:07 pm ] |
![]() sawyer 2x3 arms |
| Author: | bmoore [ Fri Dec 10, 2010 12:06 am ] |
looking forward to your airbag conversion |
| Author: | perrib [ Fri Dec 10, 2010 9:22 am ] |
Nice build and pictures. One thing you may end up changing is your bracing from the front hoop to the crossover tube. I installed mine that way for access to the tool boxes. After every ride cracks at the main hoop where they attached and at the cross over tube to main rails occured along with the main tube cracking in front of the crossover tube. I cut them out and went to the triangulated bracing in the picture.
| Author: | ridenrace6 [ Fri Dec 10, 2010 3:24 pm ] |
so perrib are you saying that setup dont crack as bad? also in the pic it's not vivible where the brace ties in at the winshield bar? |
| Author: | perrib [ Fri Dec 10, 2010 4:22 pm ] |
Check the pictures here. There are pictures of the original frame, when I modified it like yours and the latest x bracing. http://www.woodsbuggy.com/index.php?opt ... 759d20d32f |
| Author: | giveitagallon [ Sun Feb 06, 2011 11:42 am ] |
Here are some winter mods i have been working on hope you guys enjoy ! ![]() A picture of the new 6 rib and a back veiw of the buggy . ![]() Here is a picture of the new suspension seats that are going in , sure they are more comfy then the poly seats ! ![]() Here is a picture of the SUBARU 2.2 ENGINE that i went to p.a to pickup off of brad59dzl , thanks again brad ! ![]() ![]() The wire harness before its cut ![]() Brad (Hillaholic) hooked me up with a sweet deal on my new aluminum floor and some extras , thanks again brad !! Now i took off the 150 ponf 3/16 steel diamond plate floor that was on it ! ![]() I WILL KEEP THE PICTURES COMING AS I GO FOR YA GUYS ! |
| Author: | bradley59dzl [ Sun Feb 06, 2011 12:10 pm ] |
Alright time to get to work!!! Need anything else let me know.. |
| Author: | MadMike [ Sun Feb 06, 2011 12:18 pm ] |
Good to see someone doing something other than whine and moan. Looks great, almost there. |
| Author: | passat2800 [ Sun Feb 06, 2011 12:27 pm ] |
Awesome! I love home made fabs and w/c! |
| Author: | plumberbill [ Tue Feb 08, 2011 12:26 pm ] |
welcome to the dark side |
| Author: | wildcatoffroad9606 [ Thu Feb 10, 2011 11:04 pm ] |
keep the pics coming looking good |
