It is currently Mon May 04, 2026 5:13 am
 Post subject: Time to start building
PostPosted: Sun Oct 05, 2008 9:36 am
Well I had posted this already and I deleted it hitting the wrong tab so here is goes again.
I have my frame from Predator Buggies and I have to say thank you to Jeff he is a great guy and I owe him a lot. I have been sanding and getting the buggy and primed. Hope to paint it sometime in the next week if all goes well. I have added the seat mounts, but don't know where I am going to put the gas tank or my light tabs. I hope to be able to get a floor in it soon to, have to save some money up for that one.
PostPosted: Sun Oct 05, 2008 9:46 am
looking good
now get it ready for thanksgiving
PostPosted: Sun Oct 05, 2008 1:25 pm
I was wondering if you started your new car yet! Looking good :D
PostPosted: Sun Oct 05, 2008 9:53 pm
Here is a link to all the pictures that I have taken so far. Its coming along but I am going to take my time and get everything figured out where its going to go. I have the shifter rod to make, the cutting brake mount to make and weld in. Trying to get all the welding stuff done before it goes to paint. Still haven't decided on where to put the light tabs for brake and head lights. Have decided to paint it Silver Metalic with a flake over coat talk about blinging. It will look sharp for about the first 20 minutes on the first ride then it will be scratched up and dented probably. Still havent decided where to put the electrical box and switches.
The Wild Kids
http://s44.photobucket.com/albums/f35/t ... r%20buggy/
PostPosted: Sun Oct 05, 2008 10:48 pm
bout time i thought ya quit
PostPosted: Mon Oct 06, 2008 1:44 am
No hadn't quit, divorce and no job has killed me this summer. I will be back and better than ever soon.
The Wild Kids
PostPosted: Wed Oct 08, 2008 8:26 pm
During the rail today I got the floor sheeting and now ready to lay out the lines to cut it to fit the frame. Thats going to be a fun job. Have to run the tubes for clutch cable and throttle cables and then mount for the cutter brakes then off to paint. Maybe soon it will be running and ready for a test ride.
the Wild Kids
PostPosted: Wed Oct 08, 2008 9:09 pm
less than 2 months till thanksgiving
GET-ER-DONE
PostPosted: Thu Oct 09, 2008 11:49 am
Big I am working on it hope to see you and KBaby again soon too. Trying to get some other parts lined up and do all the final welding at once then paint it up. Floor should be in this weekend I hope.
The Wild Kids
PostPosted: Sat Oct 11, 2008 11:54 pm
Floor installed today and the shift rod built and adjusted up. Light tabs welded on not sure if I will have brake lights or not yet. Going to install everything and test it then tear it apart for paint. I do need to get new brake lines for it and I should be good to ride soon.
The Wild Kids
PostPosted: Mon Oct 13, 2008 5:52 am
UPDATE: Got to work on the buggy this weekend with the help from Glassman. I got the floor cut and drilled on Saturday, along with the shift rod being made. After a short trip to the ER with my son getting stung Saturday evening. He is ok now, just allergic to stings is all. Sunday I managed to get the seats installed, flooring all bolted in and looking to where my cutting brakes will sit.
SO here my question. How far from your shifter should I put the cutting brakes? I got some pictures to of the progress.
Also cleaned the tranny so I can paint it.
The Wild Kids
PostPosted: Sun Oct 19, 2008 12:44 am
Update: Well I have been busy to say the least on the buggy. When I have had free time I have been working on it. I have installed the floor the read deck and gas tanks mounted. The cutting brakes have been mounted to. I like where everything is at and the looks of it, SO I took it all apart and ready to start painting it this week if I can get a break in the weather and it warms up some. The only thing that I haven't done was the wiring but that can be done after paint and running the throttle and clutch cable tubes. The only thing that I need is some shocks to go all the way around the buggy. I hope to be able to ride soon.
Pictures will be posted after its painted.
The Wild Kids
PostPosted: Sun Oct 19, 2008 12:52 am
i saw a frame like this in florida i almost went and got i like the looks of it
PostPosted: Sun Oct 19, 2008 9:49 am
Keep up the work!!! Maybe we'll get to see you and it at Curt's
PostPosted: Sun Oct 19, 2008 1:23 pm
I hope so its been awhile since I have seen everyone. Who all is coming?
The Wild Kids
PostPosted: Mon Oct 20, 2008 7:57 pm
Well this is what all I was able to get done today. I painted the tranny and pin striped it.
Then sanded and cleaned the frame then painted it. So I didn't get much done, well sort of anyways.
The Wild Kids
PostPosted: Mon Oct 20, 2008 8:19 pm
It is looking very nice, I am looking forwards riding with you someday, but I am going to ride in Lewis County, KY for the Turkey Run day after Thanksgiving. Keep up with the good work! 8)
PostPosted: Fri Oct 24, 2008 10:00 pm
I got the floor back under it the seats installed the pedals and cutting brake handles, shifter and shift rod installed. The motor and tranny are in and bolted down. All I have to do is the wiring and running the cables for throttle and clutch tomorrow and then Monday if the parts I ordered are in I will have the wiring done. Also have to redo the brake lines.
The Wild Kids
PostPosted: Fri Oct 24, 2008 10:03 pm
You are making wonderful progress.. keep up the good work,,see you soon in the woods :wink:
PostPosted: Sat Oct 25, 2008 7:35 pm
Some new pictures of the progress I have made this weekend so far. Got the clutch cable and tube mounted and the throttle cable and tube mounted should have the brakes in tomorrow. SO if all goes well this week and I can work on the wiring I will be going on a test ride very soon.
The Wild Kids
PostPosted: Fri Oct 31, 2008 9:45 pm
Well I got my pedals sooner than I thought I would and have them installed and lines ran and bled. I have the motor tore partially done to put on the new windage tubes and a good cleaning. I hope that I will have it together tomorrow afternoon and maybe started and running. I hope so its been a long time coming and I am ready for it. The Wild Kids
PostPosted: Fri Oct 31, 2008 9:54 pm
GET-R-DONE
PostPosted: Sat Nov 01, 2008 10:48 pm
Well I should be able to start it tomorrow after church if all goes well. I have the motor back together with only a few changes in plans. Valves adjusted, oil back in it. Battery is installed and ready to be hooked up, the only wiring I have to do is for the headlights. Two wires and that will be done so no biggy. I have to take the gas can tomorrow to church with us to get some gas and it should be running. Going to get some cleaner and redo my CV's and clock them again to make sure that they are done. Only major thing that I want to do is adjust the torsion again its not set right for the new frame. I can't wait to drive this thing tomorrow afternoon.
The Wild Kids
PostPosted: Sun Nov 02, 2008 10:04 pm
Looking Great Wild Kids!!
Bryan
PostPosted: Thu Nov 06, 2008 12:29 am
Its running finally, I started it tonight and its ready for a test ride this weekend and campout. I will be taking pictures and posting them Sunday. Thanks to Jeff at Predator Buggies hes a great guy and would tell anyone looking for a frame to call him. Thanks to Joel the Glassman, Larry at the SpeedShop, Scott aka Slim your advise help and parts have made it possible for me to ride again with my son.
The Wild Kids
