PostPosted: Wed Aug 13, 2008 4:49 pm
basic stock stuff but more to come hopefully
PostPosted: Wed Aug 13, 2008 4:57 pm
Whats the wheel base on that thing? it looks like a wheelie machine!!
PostPosted: Wed Aug 13, 2008 5:03 pm
Cool pics!! Thanks for postin
Bryan
PostPosted: Wed Aug 13, 2008 8:47 pm
i know it runs good seen it at the tough truck race fri. night
PostPosted: Wed Aug 13, 2008 8:54 pm
just walked out to measure 78'' lol almost as long as wide :)
PostPosted: Wed Aug 13, 2008 9:24 pm
78 holy hell batman. cool lookin bet its real fun in the tight stuff.
"Lets go get stupid"
PostPosted: Thu Aug 14, 2008 3:50 am
Yea I seen that buggy at Croton looks like you had fun! We'll have to go ridin some time.
PostPosted: Thu Aug 14, 2008 11:54 am
havent had it on anything to steep yet but hopefully soon
PostPosted: Fri Aug 15, 2008 7:27 am
Ittle be a fun woods buggy
Every man loves a set of TWINS especially sitting on a dragster
PostPosted: Sat Sep 13, 2008 8:57 am
added couple things
PostPosted: Mon Sep 15, 2008 10:56 am
Coming together. A few words of advise. If you need to drill thru the frame tubing you should weld sleeves in the hole so the bolts dont crush the tubing and become loose. Also this retains the strengh and stops water from entering the tube and rust it out.
PostPosted: Tue Sep 16, 2008 11:35 am
good idea, i might give it a whirl when i pull it apart.... what do you use to sleeve it?
conduit is prob way to big....not sure what else to use
PostPosted: Tue Sep 16, 2008 12:49 pm
You can buy tubing in various sizes. Get tubing with an ID a little larger than the bolts you are using. Another approch that would be less work is to weld tabs on the tube to bolt your plates too. That way your not drilling thru the Tubing. AA-MFG.com is a good place to get tabs. They are prety cheap on pricing.
Heres a link right to the tabs:
http://www.aa-mfg.com/pdshop/shop/categ ... x?catid=10
PostPosted: Tue Sep 16, 2008 1:53 pm
thank you for link, ill keep that in mind and poss try and weld the holes shut this winter and then convert over to tabs like you talkd about, i was using 5/16'' bolts so i could check lowes or somewhere for pipe like that
PostPosted: Tue Sep 16, 2008 8:46 pm
Not Pipe!!! Tubing, there is a difference go to a steel supplier I'm sure if you look you can find one local if you can't find a local one contact your local High school metal fab teacher and see where they buy steel.
