subie turbo build
http://woodsbuggy.com/phpBB3/viewtopic.php?f=23&t=17635
Page 1 of 3
Author:  subieturbo [ Mon Feb 02, 2015 4:55 pm ]
Post subject:  subie turbo build
will post pics soon!!! starting a new build guys.. i rolled the red buggy at rush in oct next time ill leave the yager at home :evil: so i went out and bought a beeline explore frame... going to a kingpin front end 6 over 1 x 4 front arms with combo spindals.. im adding a turbo from outfront motorsports say 450hp at the crank on 20psi.. its a pretty cool setup we will see what it puts down at the wheel in a couple months.. i got aftermarket ecu stinger and a prog boost contorl so i can adjust the psi on the fly from my seat 7psi to 20psi plan on keeping it around 12. running it on e85.. new fuel rails with 83 pound injecters.. top mount intercooler with scoop. i rebuilt the motor last yr 2.5 subaru with h beam scat rods and cp piston, arp bolts. i know i missing somethings.. i think it should be pretty wild and cant wait to get it out. im shooting for may but we will see..
Author:  shanejrobinson [ Mon Feb 02, 2015 5:08 pm ]
Post subject:  Re: subie turbo build
ImageImageImageImagewill post more.pics soon
Author:  shanejrobinson [ Mon Feb 02, 2015 5:32 pm ]
Author:  bige70chevy [ Mon Feb 02, 2015 6:18 pm ]
cant wait to see it rip up some hills!!!
Author:  BooBoo [ Mon Feb 02, 2015 9:42 pm ]
5 G's for a turbo setup?? Damn
Author:  shanejrobinson [ Mon Feb 02, 2015 9:52 pm ]
I'll strap you in it booboo and see if you think its worth it. ;)
Author:  Odyknuck [ Mon Feb 02, 2015 10:11 pm ]
What compression pistons did you put back in the engine? Stock is 10.5 to 1 and will not handle any more than 8-10 PSI of boost and that's with a perfect tune.
Author:  shanejrobinson [ Mon Feb 02, 2015 10:13 pm ]
Don't no where you got your info from 8.5 to 1
Author:  shanejrobinson [ Mon Feb 02, 2015 10:21 pm ]
Depends on the yr as well some early 2.5 had 10.1 think 99 and early
Author:  RaceBugg1098 [ Tue Feb 03, 2015 9:35 am ]
if it had a turbo in stock form, it is likely 8.5:1. if it was N/A, then 10.5:1.
Author:  shanejrobinson [ Tue Feb 03, 2015 12:08 pm ]
And a lot of guys with 9.1 and 10.1 pushing over 20 psi depends on tune and has to be race gas or e 85 from what I've seen seen some guys up around 27 these are guys on the street which I think at 12 will be plenty on the dirt
Author:  MadMike [ Tue Feb 03, 2015 8:09 pm ]
And what transmission are you going to blow up I mean run with that boost? More power to ya if you get it to work but I'm thinking too much is too much.
I have an all Aluminum small block Chevy, you name it, it has it. Cloyes, Jessel, Aries, Hillborn, Vertex, Cower, 800HP worth. The only thing stopping me from building a buggy around this motor is, the $25,000 transmission it would take to hold up to that much HP.
Just Sayin'
Author:  dunebuggynut [ Tue Feb 03, 2015 8:20 pm ]
Just Sayin'
And that quote sums up the reason I never built a buggy that topped 150 HP
Author:  Red Barron [ Tue Feb 03, 2015 8:37 pm ]
Hey Mike it's only money looks like he has so stoke the fire and set some a blaze
Author:  Cush53 [ Wed Feb 04, 2015 3:24 am ]
Just Sayin'
Hey if you need some extra room around the shop I'm sure I could store that for you under the hood of something I got laying around ;)
Author:  shanejrobinson [ Wed Feb 04, 2015 10:47 am ]
I have a six rib, diff and weddle gear set. I plan on building another trans this season.. Should hold up awhile I hope.. If it gets me threw this yr I'll be happy. Mike Robinson and terry putting down some HP on there trans... I'll have to try to be easy on it this yr but we will see
Author:  shanejrobinson [ Wed Feb 04, 2015 10:52 am ]
From what these guys say out west in the sand with this set up they don't even a gear set but are having there trans gone threw once a year... I'm new to all this just wanted something different if it works it works if it don't back to the drawing bored..
Author:  MadMike [ Wed Feb 04, 2015 3:03 pm ]
So far you've committed two fatal mistakes, first you tried to relate to what "they do on the street" and then you tried to compare what "they do in the sand". Sorry champ, don't work like that.
On the street it's all wheel dive and they never leave the ground. In the sand, hell, try to find a more compliant, user friendly terrain to ride around on besides the local country club.
Author:  bige70chevy [ Wed Feb 04, 2015 6:39 pm ]
if your not dumpin the clutch at 9000 or landing under throttle it will be fine...if you don't like it, give it to me. ill drive the wheels off that sum bitch!
Author:  BooBoo [ Wed Feb 04, 2015 6:41 pm ]
I ain't riding in that thang. I seen what you done to the last one! Just remember one thing; you can have all the power you want, but if you can't get it to the ground then what's the point? Not trying to knock it because I'm all up for someone trying something different, I just know you'll have to invest more than 5G's into a transmission that CAN put it to the ground. More power, more problems.
Author:  shanejrobinson [ Wed Feb 04, 2015 11:28 pm ]
For one madmike I was talking about motor setup on the street said nothing about dirt... For two sand is hard on trans constant high rev and pressure of the sand is rough on things... Run your ass across the beach then run your ass across dirt I bet your faster across dirt and will be less winded... Bige70chevy seen my ride last yr and i can ride... Not like we coming off a jump and I'm going to have it to the floor when i land and this is not a 800hp alum block motor rock bouncer buggy... We do a lot of trail riding with are rigs.. Champ
Author:  shanejrobinson [ Wed Feb 04, 2015 11:30 pm ]
And it just like drag racing booboo you can have a 1000 HP motor but you have to build everything around it to handle... The trans is my weak point right now but next yr it will be upgraded...
Author:  shanejrobinson [ Wed Feb 11, 2015 8:51 pm ]
Author:  bige70chevy [ Thu Feb 12, 2015 6:12 pm ]
wheres the cooler mount? and your gonna need at least a 10 gallon fuel tank cuz were goin deep in the woods this year
Author:  shanejrobinson [ Thu Feb 12, 2015 9:59 pm ]
ImageImage have a eight gal coming and cooler passenger floor bored lol
Page 1 of 3 All times are UTC - 5 hours [ DST ]
