It is currently Mon May 04, 2026 2:18 am
 Post subject: tubeing specs
PostPosted: Wed Jan 22, 2014 4:32 am
i did a search and found this fwiw
http://mobile.pirate4x4.com/forum/gener ... st10190074
1.5 x .095 dom and hrew are both the same weight but dom is almost twice as strong and right at $1 more per foot
also did a little math, while ive never built a buggy frame im guessing there is around 100ft of 1.5 tubeing in a complete frame which calculates to 17 lbs difference between using .095 vs .083,(.095 being heavier of course) and .120 wall would be 34.3 lbs more than the .095 and would be 51.3 lbs more than .083
Chrome-Moly Tensile Stength = 90,000 psi
Diameter (in) Thickness (in) ID (in) Cross Sect. Area (in^2) Tensile Strength (lbs) Cost ($/ft) Weight (lb/ft)
1.75 0.120 1.51 0.61 55,303 $6.63 2.089 lb
1.75 0.095 1.56 0.49 44,453 $6.59 1.679 lb
1.75 0.083 1.58 0.43 39,119 $8.17 1.478 lb
1.50 0.120 1.26 0.52 46,821 $6.01 1.769 lb
1.50 0.095 1.31 0.42 37,738 $5.74 1.426 lb
1.50 0.083 1.33 0.37 33,253 $5.51 1.256 lb
1.25 0.120 1.01 0.43 38,339 $5.65 1.448 lb
1.25 0.095 1.06 0.34 31,023 $5.44 1.172 lb
1.25 0.083 1.08 0.30 27,386 $5.50 1.034 lb
1.00 0.120 0.76 0.33 29,857 $5.54 1.128 lb
1.00 0.095 0.81 0.27 24,308 $5.42 .9182 lb
1.00 0.083 0.83 0.24 21,519 $5.39 .8129 lb
1.00 0.065 0.87 0.19 17,183 $4.98 .6491 lb
DOM Tensile Stength = 70,000 psi
1.75 0.125 1.50 0.64 44,668 $5.54 2.169 lb
1.75 0.095 1.56 0.49 34,575 $5.36 1.596 lb
1.75 0.083 1.58 0.43 30,426 $5.23 1.478 lb
1.50 0.120 1.26 0.52 36,416 $5.18 1.769 lb
1.50 0.095 1.31 0.42 29,352 $5.92 1.426 lb
1.50 0.083 1.33 0.37 25,863 $5.61 1.256 lb
1.25 0.120 1.01 0.43 29,819 $5.28 1.448 lb
1.25 0.095 1.06 0.34 24,129 $5.00 1.172 lb
1.25 0.083 1.08 0.30 21,300 $5.57 1.034 lb
1.00 0.120 0.76 0.33 23,222 $5.00 1.128 lb
1.00 0.095 0.81 0.27 18,906 $5.00 .9182 lb
1.00 0.083 0.83 0.24 16,737 $5.00 .8129 lb
1.00 0.065 0.87 0.19 13,365 $5.00 .6490 lb
HREW Tensile Stength = 40,000 psi
1.75 0.120 1.51 0.61 24,579 $5.20 2.089 lb
1.75 0.095 1.56 0.49 19,757 $5.06 1.596 lb
1.75 0.083 1.58 0.43 17,386 $5.11 1.478 lb
1.50 0.120 1.26 0.52 20,809 $5.16 1.769 lb
1.50 0.095 1.31 0.42 16,772 $5.00 1.426 lb
1.50 0.083 1.33 0.37 14,779 $5.00 1.256 lb
1.25 0.120 1.01 0.43 17,039 $5.04 1.448 lb
1.25 0.095 1.06 0.34 13,788 $5.00 1.172 lb
1.25 0.083 1.08 0.30 12,172 $5.00 1.034 lb
1.00 0.120 0.76 0.33 13,270 $5.00 1.128 lb
1.00 0.095 0.81 0.27 10,804 $5.00 .9182 lb
1.00 0.083 0.83 0.24 9,564 $5.00 .8129 lb
1.00 0.065 0.87 0.19 7,637 $5.00 .6490 lb
 Post subject: Re: tubeing specs
PostPosted: Wed Jan 22, 2014 11:28 am
I hope you dont rely on those prices! I have never seen cromo cheaper than DOM and I wouldnt pay much more than $1-1.50 a foot for 1.5" erw tubing. DOM is usually a little over half the cost of cromo. If your just building a woods buggy, I would use DOM for the roof and ERW for the rest. I would bet 95% of the buggies you see in the woods are ERW.
PostPosted: Thu Jan 23, 2014 3:19 am
yeah i wasnt concerned with the price too much, mostly just the specs of the different types and sizes
