It is currently Sun May 03, 2026 5:06 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page 1, 2, 3  Next
 Post subject: Passat's buggy pics.
PostPosted: Thu Oct 11, 2012 10:37 am
Well this is it in a nut shell.
PostPosted: Thu Oct 11, 2012 10:56 am
good try your just no there yet with the pics
PostPosted: Thu Oct 11, 2012 11:33 am
DSCN0025
PostPosted: Thu Oct 11, 2012 11:34 am
DSCN0025
PostPosted: Thu Oct 11, 2012 6:53 pm
before you hit submit hit the preview button. it will show you if it posted or not.
PostPosted: Thu Oct 11, 2012 7:56 pm
If it's easier to email them to someone I am willing to post them for you. fortydegnorth@yahoo.com is my email. I use photobucket.com and then just copy and paste the "img" file on the picture from that site.
PostPosted: Thu Oct 11, 2012 8:56 pm
again.DSCN0025DSCN0025
PostPosted: Thu Oct 11, 2012 9:02 pm
Come on dd lets see this thing. Email em to somebody
PostPosted: Sat Oct 13, 2012 8:34 pm
come on dave, where are the pics?? ive seen this thing go from pile of misc parts to running, riding buggy.. its still cool to look at 8)
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Sat Oct 13, 2012 10:00 pm
ima have to come by one day and show you how to post picks :mrgreen:
PostPosted: Wed Oct 31, 2012 11:37 pm
PostPosted: Wed Oct 31, 2012 11:48 pm
It's a trick,don't do it !!!!! :lol: :lol: :lol:
PostPosted: Thu Nov 01, 2012 10:45 pm
 Post subject: Re: Passat's buggy pics.
PostPosted: Thu Nov 01, 2012 11:35 pm
PostPosted: Fri Nov 02, 2012 12:17 am
Anyway, I am new to posting.the can actually has 2-3 more inches of gap. And the diff looks tall and short.I'll get it right tomorrow.
PostPosted: Fri Nov 02, 2012 8:32 am
Now you're getting it. Let's see some more. The idea of using a differential is great to me. If you have some pictures a little further back to show engine placement and how it all ties together that would be awesome.
PostPosted: Fri Nov 02, 2012 11:27 am
the case on that 8.8"aluminum diff is from a 1994 lincoln mark 8 with a 4.7 motor and the r&p is a 307:1.The iron diffs are 327:1.But both have MASSIVE teeth that make a 483 look like a toy.The bus stock shaft has never broke but I welded the 1st diff in my 1st trans and it came apart.Let someone good at it weld for you.When everything is right they tell me it sounds like an indy car going thru the woods. I have a stretched timing chain right now,but will have it going in a few weeks.It has a 113" wheel base x 80"wide. Someday I may weld the lincoln diff but I am more of a picnicer these days.
PostPosted: Sun Nov 04, 2012 9:44 pm
PostPosted: Sun Nov 04, 2012 9:51 pm
It's a 2800 175hp but has great rpm and has plenty of muscle (torque).a few years back VW replaced the vr6 with a 2.5 vr5 170hp.Some are turbo and I don't know there output.Those are TSL 40's. (39.5")uncut.Those bigo balloon tires and long trailing arms roll over lumps and bumps with a very soft ride.
PostPosted: Sun Nov 04, 2012 10:50 pm
PostPosted: Sun Nov 04, 2012 10:58 pm
Well, there is the majic.Front wheel drive 5 speed with a welded diff.A stock bus c/v shaft to the Lincoln Mark 8 diff.The stock shifter is 2 cables 5' long. Just bolt the shifter anywhere onto the floor.I don't see how this bus cv has never broke.
PostPosted: Sun Nov 04, 2012 11:24 pm
..now ur showing dirty girls goods :shock:
PostPosted: Mon Nov 05, 2012 4:16 pm
I like the originality, Thanks for sharing the photos
PostPosted: Mon Nov 05, 2012 7:06 pm
Did you just weld flanges onto the input shaft on the diff, the output of the VW transmission and the outputs on the Lincoln to make bus cv's bolt up? By the time you go through the gear ratio of the transmission and the irs differential what does the final drive come out to? Seems like it would be really low but I guess really tall tires would help that a lot.
PostPosted: Mon Nov 05, 2012 9:09 pm
Thanks. get an old outter bus cv and thread the factory holes for 3/8 coarse.Then center it with your hands and weld it with a 7018 rod (steel).Drill the bus cv joint to 3/8 also.On the output shafts lathe the stubs to fit an old porshe 930.and basically do the same set up.Get a diff with the anti skid brake ring and make a flange out of aluminium angle to keep the output shafts from walking out.Oh and the diff has to go upside down to make it pull fwd.
