It is currently Mon May 04, 2026 12:44 pm
PostPosted: Fri Apr 06, 2012 9:51 pm
Im trying to figure out what degree/camber my rear trailing arms should be set at. They are going to be tube type 3x3's. I plan on running somewhere around 20+ degrees on the axles.
PostPosted: Sun Apr 08, 2012 3:16 pm
Unless your building them from scratch you can not effect the Camber. You bolt them on and you get what you get.
