It is currently Mon May 04, 2026 12:56 am
Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue May 01, 2012 8:12 am
Nitro, what kind of front hub/rotor are you using?
Moving your steering box to the center, did it remove most of your bum steer?
Norm
PostPosted: Tue May 01, 2012 9:04 am
Norm
Not 100% sure but I think they were CNC, got them from Tim at Southern Buggies.
And the bump steer is almost completely gone, it was horrible on the drivers side before.
PostPosted: Tue May 01, 2012 9:49 am
I dont have front brakes and stock rear drums now and dont like how it doesn't stop.
I pick up a rear disc setup and also some 4 piston calipers for the rear.
Cheap calipers but a little heavy, $31 a piece at advanced auto.
I was going to use them and then decide if I still need front brakes.
How well did yours stop with just rear disc?
I like your steering box setup.
Thinking about going that route or a grand-am rack.
Norm
PostPosted: Tue May 01, 2012 10:19 am
It stopped pretty good except going down real steep hills when the weight wont transfer and the tires would just slide. Spooked me a few times on some big muddy hills, hence the front brakes. And the reason I went with the box instead of a rack is the ability to adjust steering speed with a longer pitman arm.
PostPosted: Tue May 01, 2012 11:32 am
That a great reason to use a box.
I'm in Fl. not many steep muddy hills to slide off of.
Thanks for your imput.
Norm
PostPosted: Thu Aug 16, 2012 6:33 pm
Nitro, do you know what gm your steering box came out of I have been wanting to go to power steering and have some mid 1990 s 4x4 Chevy parts trucks sitting around just not sure if I can use them , not sure if i can turn the Pitman arm around like urs ,any input would be much appreciated thanks
PostPosted: Thu Aug 16, 2012 7:23 pm
Any Chevey truck box from like the mid 80's up should work. Jeeps use the same saginaw box as well. Mine came from CL for $25, not sure what it was in, lol. anything from a rear wheel drive monte carlo to a 1 ton dualley.
PostPosted: Thu Aug 16, 2012 9:08 pm
Ok thanks I'm gonna pull one and start messing around with it, oh and nice buggy that thing looks good
