It is currently Tue May 05, 2026 2:35 am
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed May 12, 2010 12:00 pm
so does just the high flow oil pumps let the engine run out of oil? I thought the full flow pumps actually pump oil out faster than in? Im not familuar with the full flows but with the high flow i run i have about 80 # pressure when start and about 20 after it warmed up.
PostPosted: Wed May 12, 2010 1:45 pm
Not really followin you :?
Some good points of a dry sump are:
*3 to 4 times more oil in system, therefore it lasts longer
*oil cools off more cuz it has longer route to return to engine and sits in the tank for a bit.
*dont have to worry about pickup tube not being submerged and having no oil in the pump and bearings if your sittin womperjawed on a hill because it is being picked up from the outlet on the bottom if the tank.
*with the big pumps your volume of oil flowing is increased tremendously
*oil flow is routed better
Some bad points:
*more drag on engine
*big pump sticks way out, possibly prone to damage
*expensive (but cheaper than a new a/c motor :wink: )
*fan turns slower due to small crank pulley (smaller alt pulley can fix this)
*4 oil lines mean more crap to undo when you got to pull the motor
I'm sure there are more both good and bad, but the benefits outweigh the problems , IMO.
PostPosted: Wed May 12, 2010 4:06 pm
why are there 4 oil lines ?
my buddy has dry sump and if i remember correctly he only has 2 lines going to the pump but i have seen some that have 4 lines, and was wondering what they were all for cause it seems that 1 in and 1 out would be plenty?
PostPosted: Wed May 12, 2010 4:23 pm
The ones with just two lines are the small single stage CB pumps. The big pumps like me and Dad run (he runs a Bugpack brand, I run an ARPM) have four lines. They are a two stage pump, with a low-pressure, high volume side and a high-pressure side. The bigger stage two pump just pushes way more oil, with a lot more pressure. The high pressure side goes to a normal style canister oil filter, and the low-pressure side goes to an Oberg filer, because the low-pressure size won't push through a canister style filter fast enough. We make sure our oil is CLEAN before it circulates through our motors! :D
-Daktah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Wed May 12, 2010 11:28 pm
thanks for all of that. Ive been wondering about those.
PostPosted: Fri May 28, 2010 12:42 am
well I have not been doin much lately kinda stuck on a few things and just been working 7 days a week i did however run across a brand new set of weber 40's with new CB perfromance linkage got them cheap well i thought so anyway only gave 600 bucks for them new in box
PostPosted: Sat Sep 11, 2010 11:14 pm
tried the s.s. out today had some small trouble with rear tires staying on but think i can get that lines out pic to come soon
PostPosted: Sun Sep 12, 2010 2:31 am
-Daktah/koko
can you explain how the plumbing goes on those bugpack pumps the diagram i got with my new one only shows one filter?
PostPosted: Sun Sep 12, 2010 8:58 am
Does'nt RWB have a 2 stage pump?
PostPosted: Mon Sep 27, 2010 12:34 pm
finally got the one seater finished
http://www.youtube.com/watch?v=QbpNPbdsWOs
PostPosted: Mon Sep 27, 2010 1:33 pm
looks good :D
PostPosted: Mon Sep 27, 2010 3:48 pm
It's all Pro and no Con IMO
Some bad points:
cron
