PostPosted: Fri Dec 05, 2014 6:58 pm
Bent up windshield bar today and photos of my bender I built it from Pro tools plans. except the straight shoe (aluminum piece)
Happy Hunting
archie
PostPosted: Sat Dec 13, 2014 10:27 pm
worked on the buggy some today. The second bar for the rear was a bit more difficult to bend . a little more fitting and welding. I only have to bend one more tube. one of the ones that go over the motor and weld both to the bar I am installing now. today I drug home a ball joint front beam. It is mostly junk but maybe I can salvage some parts off of it.
Happy Hunting
archie
PostPosted: Thu Dec 18, 2014 10:23 pm
The buggy has taken the back seat for a little while. there are a couple of parts for the buggy that need bent. An iron worker followed me home the other day and I have been trying to get it up and running to bend the buggy parts. I did however buy new balljoints, steering shaft and shift linkage.
Archie
PostPosted: Sat Dec 20, 2014 9:48 pm
Iron worker up and running. bent transmission mounts and shift box . Welded up shift box Worked on front end
Archie
PostPosted: Sun Dec 21, 2014 10:45 pm
some photos I uploaded today
PostPosted: Sun Dec 21, 2014 10:48 pm
more pictures
PostPosted: Sun Dec 21, 2014 10:51 pm
transmission was flat before I bent and welded it
PostPosted: Fri Dec 26, 2014 11:29 pm
More new parts. cut the drums off of the front hubs.
PostPosted: Sat Jan 03, 2015 9:56 am
Making a little more progress. All the parts and pieces to make it a roller have been gathered. Install the new ball joints and assemble the front end. assemble the the rear arms install the wheels and finish tacking up the bars.
I can't wait to be able to roll it in and out of the shop. so I can clean up and make more working room. moving the fork lift around has been problematic at best.
Happy Hunting
archie
PostPosted: Thu Jan 08, 2015 5:38 pm
The Trailing arms, adapters, wheels and tires are on. The rear is rolling, now on to the front. The tie trod are on order. and i think i am missing a few bits here and there.
PostPosted: Thu Jan 08, 2015 9:42 pm
Looks good. Keep it up
PostPosted: Sat Jan 10, 2015 12:47 am
Where you guys at in ceredo I'm in westmoreland
PostPosted: Sat Jan 10, 2015 7:54 pm
Purplerail. I sent you a pm invite
Archie
PostPosted: Sat Jan 17, 2015 9:15 pm
wondering where you went to...
archie
PostPosted: Sun Jan 18, 2015 11:33 pm
Where did u get ur torsion housing from
PostPosted: Sun Jan 18, 2015 11:43 pm
Tony at
http://beelinechassis.net/index.html
archie
PostPosted: Thu Jan 22, 2015 9:31 pm
more buggy pictures first time out in the daylight
PostPosted: Thu Jan 22, 2015 9:34 pm
more parts
