It is currently Mon May 04, 2026 3:40 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
 Post subject: Re: Tim's custom BeeLine
PostPosted: Fri Sep 18, 2009 5:10 pm
nice buggy your building,the gas tank that you have made looks good on it but make sure you mount it down so that it cannot flex at all.friend of mine had one made and just secured it on the ends and after a couple of months of riding the tank split across the bottom in the seam.not to say it will happen to yours but might be something to thank about.good luck with your build.chad :mrgreen:
PostPosted: Fri Sep 18, 2009 5:20 pm
I can't take the credit for the fabricating that is all Tony Bagley from Beeline buggies.
He is a MASTER FABRICATOR!!!!
I'll bet when Tony welds it it stays wellded!
Tim
PostPosted: Sat Sep 19, 2009 3:30 am
[quote="MoblMec"]THE XPEDITION IS BORN
Check it out!!!
sweet frame and gas tank looks like she'll be fun when she's done.
here's a slideshow of my build so far.LMK what u think....
dont be another brick on the wall!!!!CLIMB IT!!!!
http://s632.photobucket.com/albums/uu48 ... =slideshow!
!DRIVE IT LIKE YOU STOLE IT!
PostPosted: Sun Oct 25, 2009 11:20 pm
Went to Kentucky and Beeline buggies yesterday to pick up frame .
Then went to sevierville to buy Super Diff and have it installed in my 6 rib.
Got home at midnight.
Going to start paint prep tomarrow.
Here are some pics.
URL=http://s483.photobucket.com/albums/rr199/tmzspry/Buggy/?action=view&current=Frame2.jpg]Image[/URL]
PostPosted: Wed Jan 13, 2010 11:04 pm
Ok
Time for an update.
My son and I worked on the buggy over Christmass vacation. Heres what we did.
We got the buggy painted OD green . We installed all the diamondplate,Roof,Floor, Front and rear skid plate.
We also installed the Warror front beam, arms,spindles,hubs and temporary front tires.
We mounted a tow bar.
We put in the 6rib super diff trans.
Rear 2x3 swing arms with wide 5 brake rotor hubs.
Rear 13.50x33x15 super swampers on 10" wide rims.
Diamond plate gas tank.
Mounted the rear Race Trim seats and waiting on mounting the fronts untill we get shifter and peddels mounted.
Motor and Optima battery and box should go in this week.
The motor is a 1.8 built up with baby dels.
Well still lots to go.
Thanks for looking.
MoblMec
Tim
PostPosted: Thu Jan 14, 2010 12:24 pm
Looking Good!!!
Bryan
PostPosted: Thu Jan 14, 2010 2:52 pm
Coming along nicley. That 1.8 T4 should give you plenty of Torque. They are known for that. Don't expect a lot of top end however.
PostPosted: Sun Jan 17, 2010 7:39 pm
Looks good Tim, one day I'll make it over there to see it in person,glad to see those parts got you rolling rather than laying around at my house.
Bruce
PostPosted: Mon Sep 06, 2010 11:59 am
OK Time for a update.
Finally it is going after a year of building.
Heres a list of parts.
Custom BeeLine 4 seater wiyh 98 inch wheel base.
Warror 6 inch wider beam.
Saco R&P
Heim joint tie rod ends
1 inch dom tie rods.
Tilt steering
Quick detach sterring wheel
Race Trim seats
Diamond plate overhead dash with Auto Meter gauges
Drag fast shifter
CNC dule master cyl. brake pedal
CNC clutch pedal and slave cyl.
CNC single handle cutter.
Front drum and rear disk brakes
6 rib trans. with german super diff.
228 mm clutch and pressure plate
Type 4 1.7 liter motor with baby dels.
Diamond plate floor, roof, and skid plates
Original Jackman wheels 8x15 front and 10x15 rear powder coated texture black
Deasert dog 9.50x29x15 front tires and Super Swamper TSL 33x13.59x14 rear tires
I am sure I forgot something!!!
What do you think???
Heres some pics.
Thanks for looking!!!
PostPosted: Mon Sep 06, 2010 12:43 pm
Good looking buggy.This would be the buggy to take the family in and enjoy a good long ride.
PostPosted: Thu Sep 09, 2010 11:20 am
Looking Good!!!!
Bryan
PostPosted: Thu Sep 09, 2010 6:17 pm
I like it
PostPosted: Thu Sep 09, 2010 9:44 pm
Very nice lookin ride. Why didn't you run the wires to the overhead console up the windshield post instead letting them hang out there in the middle!
PostPosted: Fri Sep 10, 2010 9:36 pm
There is going to be a center windshield bar to tie that flex conduit to shortly.
That way when I put a windshield in it will be two pieces so if broken the fix will be cheaper.
MoblMec
PostPosted: Fri Sep 10, 2010 9:59 pm
MoblMec
That's a good idea!
PostPosted: Fri Sep 10, 2010 10:46 pm
It looks like you have been busy. Hope you have lots of fun with it.
