It is currently Sun May 03, 2026 5:04 pm
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Mon Oct 12, 2015 10:44 am
helmetguy wrote:
You're done now!!! No more tranny problems!!!!!!
Don't say that.... Your gonna jinx me... hahahaha
PostPosted: Mon Oct 12, 2015 11:07 am
Found a couple more pics... Had to split the trans skid down the middle. Bend it down. Cut and bend both side again and fill the middle to clear all the extra heft in the middle. Had to hack up trans mount plate as well and remake all that. And every time I welded anything I had to put the whole cage back together to make sure my tube connectors stayed lined up.
I wasn't in the mood to buy more fancy tubing connectors so I used some of my old style ones left over for the fuel cell... It used to be pinched in place with the cage, but that didn't play nice anymore in the new position.
Here is where I put the circulation pump. Short and sweet. I was able to recycle my now too short fuel lines for the trans pump system.
Halfway there...
PostPosted: Mon Oct 12, 2015 11:16 am
When they sent me the trans they sent me 2 full gallons of Swepco and it drank every bit of it..... :shock:
PostPosted: Mon Oct 12, 2015 12:06 pm
What grade swepco does it use
PostPosted: Mon Oct 12, 2015 10:17 pm
Would you mind sharing with a newb more about those tube connectors you mentioned (old style and new style)? Are they made or can they be bought?
...Tools ...Toys (same thing) :)
PostPosted: Mon Oct 12, 2015 11:26 pm
The old style are the 2 exhaust flanges bolted together
This is the "new" style
PostPosted: Tue Oct 13, 2015 6:29 am
Are the new tubing connectors only available in chromoly?
http://www.pacificcustoms.com/ac702002-120.html
http://www.piersideparts.net/LR702002-120.html
https://www.kingoffroadparts.com/store/ ... ctors.html
http://store.sevensaturdays.com/ltr-702002n.html
Here is a thread on welding chromoly to mild steel:
http://weldingweb.com/showthread.php?26 ... o-chromoly
PostPosted: Tue Oct 13, 2015 9:02 am
Swepco 210
PostPosted: Tue Oct 13, 2015 9:04 am
Wow that's the heaviest gear oil I've heard of
PostPosted: Tue Oct 13, 2015 9:06 am
Oh wait I googled it and seen its 80w 140w, I think that's what weddle sent me
PostPosted: Tue Oct 13, 2015 9:08 am
The tube connectors I got were from Pacific Customs. It was 5 years ago when I bought them. I don't recall if they were mild or Chromoly.
I didn't plan on needing more until I realized I couldn't lift the cage over the cell in the new position and I didn't want to wait 3 days for them so I used the exhaust flange style that I had.
PostPosted: Tue Oct 13, 2015 12:03 pm
Thanks! What a great build thanks for sharing
