It is currently Mon May 04, 2026 11:35 am
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Mon Mar 17, 2014 3:20 pm
newbie26 wrote:
OK do you know how those dbw pedals do in moisture. I don't plan on plowin through mud all the time. But I will be in it.
The sensor itself is enclosed. The connection is Delphi Weather-Pack. We've never run into a problem. We have guys running these in CORE and YORR off-road series without problem. The ECM's on most GM vehicles are mounted in the engine bay on the outside fender wall - they get dirt, mud, rain, salt, etc., wtthout issue... We haven't had an issue with them at all in adverse conditions. That's not saying if you submerse it in water or mud it won't fry! lol
UncleJerm76 wrote:
Could you utilize your existing throttle cable and move the DBW to the rear in a box if you are worried about the elements?
Yes sir - I've customers do this and actuate the throttle pedal via a cable in a box...
Wheel_Works wrote:
Check Out Waytekwire.com also Why not use a Relay holder like these?
http://www.waytekwire.com/item/46343/MI ... ELAY-RTMR/
Steve and TKM use those and we use them in our SCORE compliant harnesses. However, we don't use them in most production harnesses because it takes longer to build which equates to more $.
-AFI
PostPosted: Tue Mar 18, 2014 9:04 am
Guys I found this and also called the guy, now its not the same exact pedal as we use but its still a GM pedal, Sean I would like to see you do this please :lol: DBW in water
http://bdturnkeyengines.com/dbw-water/
PostPosted: Tue Mar 18, 2014 10:52 am
Haha! Jim, this is awesome!! This is going on the website!! Great find! It's not the same pedal we use, but it uses the same connections!
-AFI
PostPosted: Tue Mar 18, 2014 5:58 pm
Dunk it! Dunk it! Dunk it! I think you should have that set up at the show.. I will see you there...
PostPosted: Thu May 08, 2014 2:14 pm
The AFI car has been SLOWLY coming along [we're too busy] but we're almost ready for the dyno.
Ron Davis now is making a SPECIFIC Ecotec Radiator on AFI's design. If you are interested - please let me know!
-AFI
PostPosted: Thu Sep 11, 2014 12:33 pm
This bad car has been done for a while, just been so busy haven't had any time to post updates. Front suspension is perfect. We're working on fixing the rear as it is REAL stiff. Went 100 lbs lighter on the springs and Bordeaux is re-valving my shocks. Should be close.
It's a beast on the street, on the dunes, and on the trail!
afi_car by ALPHA FAB, on Flickr
A cool VIDEO when we were doing some trail test and tune.
https://www.flickr.com/photos/66207494@N07/15015292878/
PostPosted: Wed Sep 17, 2014 9:49 pm
A 12 second video???? You have to post more than that! Looks awesome and its nice to see it on the trails.
Bryan
Users browsing this forum: Majestic-12 [Bot] and 2 guests
