It is currently Mon May 04, 2026 2:39 pm
 Post subject: idle
PostPosted: Thu Aug 08, 2013 2:37 pm
what rpm do you guys set your buggys at i am running a 1835 with 110 cam single webber?
 Post subject: Re: idle
PostPosted: Thu Aug 08, 2013 3:02 pm
I have mine between 8 and 900rpm
PostPosted: Thu Aug 08, 2013 3:08 pm
thats where mine sounds good at but it seems to have a little stumble pulling of so i have to get the rpms up to prevent that.
PostPosted: Thu Aug 08, 2013 3:30 pm
700-900rpm whats your timing set at?
PostPosted: Thu Aug 08, 2013 3:59 pm
32 degrees at 2500
PostPosted: Thu Aug 08, 2013 6:12 pm
i ordered me some velocity stacks for my carb yall think they will help????
PostPosted: Thu Aug 08, 2013 7:44 pm
Did you just put the weber on or is this an existing problem. Maybe your accelerator pump needs turned up more. And if I remember correctly from other people post idle jets play a roll in low rpms too then the mains take over in mid to higher rpms I was having similar problems with my dual 44s but it was mid to high rpms. I'm still learning on these things too. Hopefully someone with more knowledge will chime in and give you a better idea of what to be looking for
PostPosted: Thu Aug 08, 2013 8:12 pm
not a new prob just swaped out the 60 idle jets to 55.it always ran great at mid to higher rpms.
