| Afterburnt and Davehix were right! http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=9998 |
| Author: | jayrod [ Sun Aug 01, 2010 1:53 pm ] |
| Post subject: | Afterburnt and Davehix were right! |
Well Im in Virginia for work, But I got a friend back home to tear my motor down for me and it was a rod bearing. So I guess I'll break it in a little easier this time around? Im hoping to be in wellsville with it Labor day weekend, But figured id let you guys know you were right about it. |
| Author: | chris38375 [ Sun Aug 01, 2010 4:29 pm ] |
| Post subject: | Re: Afterburnt and Davehix were right! |
breaking one in dont have anything to do with a rod bearing,could be a oil journal no oiling good |
| Author: | rockrockets1 [ Sun Aug 01, 2010 5:19 pm ] |
After breaking in the cam ,,,,run it like you gonna run it |
| Author: | buggiejunky [ Sun Aug 01, 2010 6:18 pm ] |
when u hold an aircooled vw engine wide open with the crank pulley pointing at the ground u will spin a bearing it will happen every time untill u dry sump it cause and effect the motor just simply ran out of oil |
| Author: | Stevo [ Sun Aug 01, 2010 9:46 pm ] |
15 years and never ran dry sump and still dont have a problem, I just run it with an extra quart. ac or wc |
| Author: | chris38375 [ Sun Aug 01, 2010 11:15 pm ] |
SubySteve wrote: 15 years and never ran dry sump and still dont have a problem, I just run it with an extra quart. ac or wc im with u we got some long hills here and ive never ran a dry sump and dont nobody around here,if its built right and clean u wont have a problem |
| Author: | Graden2387 [ Mon Aug 02, 2010 12:41 pm ] |
chris38375 wrote: SubySteve wrote: 15 years and never ran dry sump and still dont have a problem, I just run it with an extra quart. ac or wc im with u we got some long hills here and ive never ran a dry sump and dont nobody around here,if its built right and clean u wont have a problem Im with you buggyjunkie but there are to many experts on here so im loggin off. |
| Author: | dink2275 [ Mon Aug 02, 2010 2:22 pm ] |
i built a brand new 2275 had about ten hours on it and it did the same thing it was even dry sump and didn get ran that hard i think its just a vw thing |
| Author: | rockrockets1 [ Mon Aug 02, 2010 3:11 pm ] |
Chris there goes some one else calling you an EXPERT |
| Author: | afterburnt [ Mon Aug 02, 2010 4:43 pm ] |
i might not be no expert, but i do know what a bad bearing sounds like. its one of those sickening sounds that hits you right in your wallet. ive had my share of them. |
| Author: | chris38375 [ Mon Aug 02, 2010 5:45 pm ] |
rockrockets1 wrote: Chris there goes some one else calling you an EXPERT atleast they know me,,hahahlol |
| Author: | kevin f [ Mon Aug 02, 2010 6:16 pm ] |
All I run is a full flow system on my buggy and Ive never had a oiling problem. The only thing I do is run a windage tray to help hold the oil around the sump. |
| Author: | ridenrace6 [ Mon Aug 02, 2010 8:26 pm ] |
kevin f wrote: All I run is a full flow system on my buggy and Ive never had a oiling problem. The only thing I do is run a windage tray to help hold the oil around the sump. and didnt you tell me a 26mm or 28mm oil pump instead of the big 30mm pumps ?? |
| Author: | kevin f [ Tue Aug 03, 2010 6:36 pm ] |
Thats right chris the 30mm pump sucks the sump dry dry under high rpm and foams the oil really bad. The 26 or 28 solves that whole problem. |
