It is currently Tue May 05, 2026 12:23 am
PostPosted: Sun Jul 25, 2010 1:09 pm
i thought i had the correct axles for my 2x3 arms but dont so these axles wont work for me . i need to determin what they are so i can post them for sale . the red set measure 16 inches long and are the same thickness all the way though . the white ones are 15 and 5/8 long and the shaft narrows after the splines till it meets the splines on the other end ImageImage
PostPosted: Sun Jul 25, 2010 1:39 pm
Both are aftermarket because of the long splines. The 15 5/8 are conversion for using a bus tranny with stock length sedan trailing arms. The others are probably for sedan tranny with stock length trailing arms. Both appear to be for type 1 or 2 cv's. 930 are coarser splined
