It is currently Tue May 05, 2026 12:22 am
 Post subject: fule cell bolt pattern
PostPosted: Fri Jul 02, 2010 12:46 pm
Does any one know the bolt pattern to a six bolt fuel cell filler and the vw sending unit?
Dave
|....BUDWEISER......| ||'|";, ___.
|_..._..._______===|=||_|__|., ] -
PostPosted: Sat Jul 03, 2010 1:46 pm
are you talking about the degree markings?> I jsut got my sending unit and mount in and was about to open up the mounting instructions...I also have an auto meter one that actually tells you the degree marks for where to drill for if there is anything i can offer as far as info with the bolts pattern of the mount holes give me a call...910-520-2126...i hope this is what you are looking for...good luck!
PostPosted: Tue Jul 06, 2010 2:18 pm
I'm looking for a bolt pattern like 6 on a 4" circle. Like a bolt pattern on a car's hub.
PostPosted: Wed Jul 07, 2010 11:51 am
Yeah i know what your talking about and i think it is a 6 bolt pattern...I will check this afternoon and maybe post a picture of it...if it is a 6 bolt screw plate...good luck man
PostPosted: Fri Jul 09, 2010 10:12 am
all the plates that i have in my shop after look last night and this morning are 5 bolts...sorry
PostPosted: Mon Jul 12, 2010 8:18 am
Ok may be I'm wrong I'll look in to it I thought the filler and sending unit are 5 bolt.
PostPosted: Mon Jul 12, 2010 2:42 pm
the fuel cell that i am looking at i had in the my bug when i got the car but i do not know if the original owner got an aftermarket sending unit so i might be wrong...i am sorry if i have told you aftermarket stuff and not vw i know that this one is the same as the vdo sending unit...so i would think it would be the same since it works with the "empi" mount...again sorry if there has been confusion :oops:
